Fog Hid Kit
None
Fog Hid Kit
Hey guys i just recieved new 6000k headlight bulbs for my stock bixenon and i also bought a hid kit for my fog lights from http://www.cqlight.ca they are very high quality and took about 20 minutes to install and the best part no check lamp message on the dash and all power from stock headlight harness i am very happy here are the pictures enjoy
Thanks for the info. I'm not sure if I'll do a true HID conversion on the fogs rather than just substituting a bulb that looks whiter to go with the bi-xenons.
Originally Posted by ItalianStallion
That's what I did, I changed the parking and fog bulbs so that they have the same color as the xenons...it looks so much better. But xenon fogs must be awesome, I'd ride around with just the fogs on :p
I'm not exactly sure, but I think they are called H7's (they are fake HID Xenons)...sorry, wish I kept the box...they are not even close to the brightness of the HID's, and when the HID's are on you can't see the blinkers or parking lights from far away.
04 CLK55
None
lol i used industrial strength velcro to secure the ballast as a temp. solution it has held well. Not sure about drilling holes in my car. There are plenty of mounting location in the bottom of the engine compartment.
2002 C230 Kompressor Coupe
my low beams are 6500k and my fogs are 8000k
Check out http://www.seekspeed.com
Rated #1 xenon in the world~
05 E500 4matic, 08 ML320CDI
The website he listed has the 9006 Fog Light HID's kit for $179.00... I don't mean to answer for him, just that I looked into the kit also... $179.00 seems quite reasonable compared to some HID kits I've seen on the net...
SMD
None
The kits has held up over year now and i have no complaints. It has a seperate igniter and ballast. Some more expensive units like over 300 have a igniter and ballast in one unit. Overall i believe the kit is well made and has held up well. I dont believe theirs a better value out there.
CLK W209 2007
Hi
So, I will need the 9006HID Conversion kit for my fog lights?, and will another set of H7 HID Kit fit into my High Beam Light?
Another question, what is the best side light that I can get? possible for a HID Side light??
Please let me know!
I got my head light converted today and it looks the nuts!, (You can see in the other post!)
Please let me know!
None
Yes, your correct 9006 for fogs and h7 for highbeams. For highbeam i would go with the 5000k for the most output after about 5800k the lumens start to decrease. I have 6500k in my lowbeam and 8000k in my fog. If i had to do it over i would have done 6500k in lowes and 6500k in my fogs for more light. The 6500k is a perfect balance for colour and light.
need help with hid bulbs
I tried to install mine today on my w209, I received 2 malfunctions and the lights flicker and won't stay on. Does anyone have carlabs #? Does anyone have suggestions? I thought this unit was plu and play.... I guess I'll have to use my high-beams for now.
2007 Mercedes CLK350
