can I make my ipod work in my 04clk 320
Old May 3, 2006 | 01:31 PM
lowblue320's Avatar
CLS w/ 360 Forged wheels......
I would like to make my ipod work with my radio is it possible? Thaxs in advance
Old May 4, 2006 | 11:20 AM
Stiggs's Avatar
2003 CLK55
Do you have a CD changer in your car. If you go to mp3yourcar.com you can find a hookup that takes the place of your CD changer. It lets you use the steering wheel controls. But you lose the CD changer.
Other option is do you have command? Does it have an AUX input. If it does then you can run the iPod through that with a cable you can get from the dealership...I believe.
Stiggs
Old May 4, 2006 | 01:42 PM
clkcadet's Avatar
S550
there are a couple of avenues to make this work
here are a few options
option 1, if you have a navi you have an aux input standard from the factory
option 2, install an FM Modulator (inexpensive)
option 3, buy a full fledged ipod integration kit (expensive)
Old May 5, 2006 | 06:43 PM
Stiggs's Avatar
2003 CLK55
Every thread I've looked at says the FM modulators are crap. They sound crappy.
I don't know if this is true or not because I don't have one.
Old May 5, 2006 | 07:28 PM
clkcadet's Avatar
S550
a few of my friends have it, it sounds pretty good. one friend has it in a clk500, and he swears by it, personally i use the aux input that came with the car
Old May 8, 2006 | 03:12 AM
rrichard's Avatar
CLK500 (W209), Audi RS5, Harley NightRod Special, Suzuki GS1000
Hi, I have the command unit with Sat Nav, where will I find the Aux input? I want to connect my Iriver MP3.
Richard
Old May 8, 2006 | 01:43 PM
clkcadet's Avatar
S550
easy!
simply open the glovebox and near the 6 disc changer on the right side you will see a small hole.
simply head to radio shack and pick up a mini to mini cable (looks like two headphone jacks) for about 5 bucks and plug it in there and the other side into the ipod
use your command to get to the aux function and there you go!
Old May 31, 2006 | 10:33 PM
cristo's Avatar
I have a 2003 CLK430 cab, with 6 CD in trunk and NAV, where can I find my aux hookup for my IPOD mini and is that what you recommend ? What controls in COMAND system would let me control IPOD ?
Old Jun 1, 2006 | 01:39 AM
clkcadet's Avatar
S550
Originally Posted by clkcadet
easy!
cristo, try this method i hope its the same, if its not then you might not have it
Old Jun 2, 2006 | 07:43 PM
cristo's Avatar
mu CD change is in truck so can't see behind it?
Old Jun 2, 2006 | 07:46 PM
cristo's Avatar
Here's a question assuming the AUX hole is there in trunk CD, I would basically have to leave the ipod laying in the trunk ? How does AUX input get turned on to use the IPOD through the COMAND?
Old Jun 8, 2006 | 05:35 PM
caigy's Avatar
It's easy to find the small hole on the right side of the glovebox that accepts the mini-jack cable for the IPOD. It's silver-colored. But I can't find any way to select AUX on the COMAND in my 2004 CLK320 Cabriolet. There is no Aux button on the COMAND (only SAT, AM/FM, NAV, etc.) and there doesn't seem to be any menu choice on the screen. How do I select AUX? Thanks.
