2007 CLK550 Specifications
Old Jul 1, 2006 | 04:33 PM
Peanuthead's Avatar
2009 C63 AMG
Talking 2007 CLK550 Specifications
I have the specifications for the 2007 CLK550, CLK63, CLS550 and CLS63 AMG's.
I will post the data in each of their respective forums.
This data should be available on the mbusa.com site soon.
I am posting only the pertinent information, including:
* Engine and Drivetrain
* Chassis
* Performance
* Exterior Features
* Interior Features
* Instrumintation
2007 CLK550
MSRP TBA
Engine5.5L 32-valve V-8 engine
Net Power382 hp @ 6,000 rpm
Net Torque391 lb-ft @ 2,800 - 4,800 rpm
Engine 5,461-cc DOHC 32-valve V-8. High-pressure die-cast alloy cylinder block. Alloy heads.
Net power 382 hp @ 6,000 rpmNet torque 391 lb-ft @ 2,800 - 4,800 rpmCompression ratio 10.7:1Fuel requirement Premium unleaded
gasoline, 91 pump octane.Fuel and ignition system Integrated sequential multipoint fuel injection and ignition includes
individual cylinder control of fuel spray, spark timing/phase, and antiknock. Electronic throttle. One high-energy ignition
coil and spark plug per cylinder, with 100,000-mile spark plug intervals.
Intake system Dual overhead camshafts with continuously variable intake and exhaust timing. Magnesium 2-stage resonance
intake manifold increases intake runner length at lower rpm for improved response. Electropneumatic turbulence flaps at start
of intake path help increase intake airflow speed at midrange rpm for greater air-fuel mixture swirling and stronger, more
complete combustion.
Transmission Driver adaptive 7-speed automatic. Electronically controlled shifting. Driver-adaptive programming adjusts
shifts points to the driver's current driving style. Touch Shift allows the driver to manually downshift and allows upshifts
by nudging the shift lever left or right from the Drive position. Shift into Optimum Gear programming allows one-touch
selection of the best gear for maximum acceleration or engine braking by holding the shift lever to the left of Drive for one
second. Driver-selectable Comfort mode starts the vehicle moving in 2nd gear or a second Reverse gear, and upshifts at lower
rpm, to help improve control on slippery surfaces.
Drive configuration Rear-wheel drive.
Rear axle ratio 2.65:1
Performance
Acceleration1 0 - 60 mph in 5.1 seconds.
Fuel economyEPA estimate2 TBA
Highway estimate3 TBA
Emission certification TBA
Exterior Features
Black grille with three chrome ribs.
AMG-designed front air dam with mesh air intakes and chrome-ringed round front forlamps. AMG-designed side skirts and rear
apron.
Color-keyed AMG-designed rear spoiler on the edge of the trunk lid.
Dual polished chrome AMG exhaust finishers.
Red and smoke-color rear lamp covers.
Dual power mirrors, linked to the driver's seat memory and automatically heated.
Auto-dimming left-side mirror.
Electrically heated rear window with auto-shutoff based on time and outside temperature.
Dual aero-blade windshield wipers. Heated windshield washer nozzles.
Infrared rain sensor automatically adjusts the wiper speed and intermittent wiper frequency from infinite delay to fast
wiping speed based on the amount of rainfall measured on the windshield.
Variable-focus halogen headlamps with clear high-impact polycarbonate lenses.
Halogen front foglamps, in front apron. Single red rear foglamp integrated in the left taillamp cluster.
Driver-selectable light-sensing headlamps can be set via the Auto position of the headlamp switch to automatically illuminate
in darkness, and when entering dark tunnels or parking garages.
Driver-programmable daytime running lamps illuminate low-beam headlamps at reduced intensity (full intensity for optional
Bi-Xenon headlamps) in daylight, with auto-on override in darkness.
Automatic lamp substitution uses a nearby lamp if a critical bulb fails.
Touch Turn Signals flash three times with one touch of the turn-signal lever, for lane changing. Auxiliary LED turn-signal
indicators are integrated with side-mirror housings.
Interior Features
Digital dual-zone automatic climate control with individual left and right digital temperature controls and rotary airflow
distribution controls, automatic control of blower speed and airflow distribution (with manual override), sun sensor,
humidity/dewpoint sensor to help reduce window fogging during humid weather and help prevent overdrying of cooled air, and
activated charcoal filter with smog-sensing automatic recirculation of filtered cabin air. Dash-top diffuser vent. Rear-cabin
air vents at rear of front console. Electrostatic dust and pollen filter. Tunnel mode offers one-touch closing of all
windows, the sunroof (if equipped), and cabin air intake by pressing and holding the air-recirculation button. Pressing the
button again restores previous window and sunroof positions. Multifunction steering wheel provides convenient, additional
controls for the basic functions of the audio system and optional phone, plus operation of the multifunction display.
Fingertip shift paddles located behind the steering-wheel spokes. Power front and rear side windows, with one-touch
express-up/down for front windows. 4-way (tilt/telescoping) power steering column, position-linked to driver's seat memory.
Electronic cruise control. Delayed-shutoff front and rear courtesy lamps. Entrance lamps in both doors. Dual front reading
lamps. Dual sun visors with illuminated vanity mirrors. Auto-dimming rearview mirror. Front center console with rolltop
cover, enclosed storage compartment, and removable dual cupholders. Retractable storage container. Pockets in both doors.
Parcel net in right front footwell. Magazine pockets on both front seatbacks. Folding rear center armrest with slide-out dual
cupholder. Open center console between rear seats. Illuminated, carpeted trunk. Integrated garage door opener. Dash-top
diffuser vent. Rear-cabin air vents at rear of front console. Electrostatic dust and pollen filter. Tunnel mode offers
one-touch closing of all windows, the sunroof (if equipped), and cabin air intake by pressing and holding the
air-recirculation button. Pressing the button again restores previous window and sunroof positions.
Instrumentation
Electronic analog speedometer, tachometer and quartz clock. Electronic bar-graph fuel and coolant temperature gauges. Ivory
color gauges with soft blue backlighting, chrome rings, and matte chrome surround. Digital display for the odometer and Touch
Shift gear/mode selection. Multifunction display in the center of the speedometer, scrolled via the steering-wheel controls,
to operate and display various menus and vehicle features including the resettable trip meter and outside temperature
indicator; digital speedometer, maintenance system, and engine oil-level check; radio station, CD player, CD changer
(optional), iPod playlist/track (with accessory iPod Integration Kit); navigation system route guidance (optional); vehicle
reminder and malfunction messages; driver-programmable settings for instruments, lighting, vehicle, and convenience features.
Also includes controls for trip computer (elapsed time, fuel consumption, distance to empty) and optional cellular phonebook.
Mercedes-Benz maintenance system displays the distance remaining until the next basic maintenance service, indicates the type
of service due, and provides an automatic reminder feature when the service interval draws near. Audible reminders and
messages for open door or sunroof (if equipped); exterior lamp failure; low fuel, engine oil, coolant, and washer fluid
level; and to release parking brake, switch off headlamps, and remove the ignition key.
Old Jul 1, 2006 | 09:34 PM
clkcadet's Avatar
S550
nice, good luck to all those ordering, it sounds great with that new engine!
Old Jul 8, 2006 | 07:16 AM
RaCorm's Avatar
Pricing for the 07 CLK
Base price for the CLK550 coupe is $54,900 and the CLK550 Cabriolet is $62,900.
Old Jul 9, 2006 | 12:15 AM
Danke's Avatar
deposit paid on '07 CLK550 Cabriolet. wait wait wait. WIFE has '01 BMW 330Ci
Wow! A month ago I started talking to the dealer about a Euro delivery of a CLK550 in September. We've been waiting on the details of the '07s so we could place an order. I was very pleased to hear of the larger engine in the '07 and was expecting a bit of a price jump because of it. But, if these prices are correct, the price went down as the base for the '06 CLK500 was a little change over $63k. When I was chatting with my Sales rep today, she said she'd have prices on Monday, so I reckon I'll find out soon
Old Jul 12, 2006 | 12:15 AM
TracerHawk's Avatar
BMW
Wow, I really like the numbers on the CLK550. Any idea what the weight of this car will be? Under 3600 lbs?
Old Jul 13, 2006 | 07:23 AM
Germancar1's Avatar
2013 650i Coupe, 2010 IS250 AWD, 1999 S500
Per MBUSA, the Cabrio is 3965lbs and the Coupe 3720lbs.
M
Old Jul 13, 2006 | 10:20 AM
onkelmarknr1's Avatar
CLK 500 Convertible
Why is it that the german mercedes always have more horsepower then the american versions. For instance the new clk 500 (german version got 388 horsepower the american only 381. Does anybody know why? Also we have to use a higher Octan gas then you guys do. The american only requires 91 ours need at least 95!
Old Jul 13, 2006 | 10:22 AM
vraa's Avatar
Probably due to different methods of rating horsepower -- or it could just be paper advertising numbers.
Old Jul 13, 2006 | 11:16 AM
ItalianStallion's Avatar
R35 GT-R, EvoX
I wish they sold 95 octane around here. All I can get is 93 but I use a NOS Octane Booster which is supposed to bring me to around 100 Octane. Good stuff.
Old Jul 13, 2006 | 02:44 PM
CLK 500 Convertible
you can get 100 Octane at almost every gas station overhere pfpfp
Old Jul 13, 2006 | 02:50 PM
CLK 500 Convertible
maybe that could be it. but i am still wondering why we not suppose to get less that 95 Octane. maybe there is a lil' difference in the engine?
Old Jul 13, 2006 | 03:38 PM
Stiggs's Avatar
2003 CLK55
Does the new CLK550 weigh more than the 2003-05 CLK55??
If its basically the same car, then why is the 0-60mph only 5.1. With all the extra horses shouldn't it be at least as fast as the CLK55?
Old Jul 13, 2006 | 03:49 PM
mrkbbd's Avatar
'05 MB CLK 320A; '06 BMW X5 4.8is
it probably is, I bet they (mb) can't say it is b/c then it is beating some of the amg cars on paper and I believe the 55 is still being sold / available
Old Jul 14, 2006 | 03:03 AM
Germancar1's Avatar
The 55 models are history, worldwide.
The different hp numbers is just conversion from German DIN to SAE, not an actual difference in power.
M
Old Jul 14, 2006 | 10:21 AM
Stiggs's Avatar
2003 CLK55
My point is not about horsepower...its about published 0-60 times. How convienent its 5.1sec and not less. I would bet dollars to doughnuts it is faster than the CLK55 but they are not allowed to say it. Imagine how pissed the AMG guys would be. A non AMG car in the same class is beating them. It kinda sucks. Thats why I feel they should've waited for the new body style to introduce all these new motors. ....550.....63...etc. Then it would seem to make more sense.
Old Jul 17, 2006 | 08:24 AM
hobie's Avatar
'02 C230K
a 2.65 gear? any new colors?
Old Jul 17, 2006 | 08:44 AM
Germancar1's Avatar
I seriously doubt it has anything to do with the old CLK55, MB's numbers are always conservative. As for waiting for the new body that is years away and the CLK500 was being overpowered.
M
Old Jul 17, 2006 | 11:51 AM
mcbaes72's Avatar
I wouldn't get mad if the 550 was faster. I'll just take out a 2nd mortgage and buy a $16K Renntech S/C to bring her car up to 460 hp. Problem solved.....j/k (in case wifey's reading this thread). LOL!
