Center dash trim piece removal
1 Post
R230
Wondering if someone could give me a hand...all of the searches come up with vague and confusing comments.......
I need to remove my center console wood trim pieces in my '04 W209.
Anyone have a rudimentary walk thru? Appreciate any help...
2015 E250D
1. open ashtray
2. pull up on shifter console piece first. From front
3. Disconnect wires
4. Twist off bottom portion of shift knob and pull up knob.
5. Next remove ashtray. Use a small flat screwdriver to pull tabs towards rear. There are 2 tabs.
6. Look behind ashtray and you will see 2 metal wire clips. Pull these down with a hook or a small flat screwdriver.
7. Pull the wood trim out from bottom.
8. disconnect wires.
3. Disconnect wires
2012 CLS63
1. open ashtray
3. Disconnect wires
3. Disconnect wires
1 Post
R230
Ok thanks..........but I still have an issue with the last main piece......will not budge and I do not want to break anything. I have the shift console off, shifter off, ash tray off......I just need to pull off the main piece that surrounds the stereo hu, buttons, and climate..........need help asap.......
2012 CLS63
Good thing you got it, I read this post too late. I cant believe I forgot to mention those torx screws. Sorry, but good thing you found the problem.
Jon
Jon
1 Post
R230
