2003 CLK 320 Cluster Removal
I would like to take my cluster out to replace it with a new one, but at the same time i dont want to experiment and put scratches all over the place. Could someone please help. i did look at a thread which showed how to remove clusters for W208. (would it be the same for w209?).
Additonally, if i put the new cluster in, does it give errors or so. How could those errors be avoided? Please help.
Thanks in advance for the help.
When I inquired about purchasing a CLK55 AMG instrument cluster for my CLK500, Steve (MBenzNL) said that I would need to replace it at the exact same mileage in order for it to function correctly.
Please post if you know otherwise. I would still like to swap mine out as well.
Thanks ...
Yes The Miles Should Match as if one installs a combi with LOWER mileage the REAL Mileage IS also stored in the EIS and ME control units
I was messing around with the speedometer and all, and i think i blew a fuse or something. The lights and the meter arent working, so could someone tell me where is the fusebox located and where are the fuses for the meter.
Thanks in advance. Please help ....
thx
