Need Help and suggestions - wheel and tire clearance
Old Jun 15, 2008 | 08:00 PM
JuicedMB's Avatar
04 CLK 320, 04 BMW 530I, and 09 HD FLTR
I just purchased a set of wheels through ebay and a set of tires from tirerack for my 04 clk320.
The wheels are 19" x 8.5" front ET 32 / 19" x 9.5" rear ET 35 (stamped on the back of the wheel). The vendor said it would fit no problem.
The tires are Goodyear F1 DS G3: 235/35-19 front / 265/30-19 rear.
I took the wheels and tires to a local Firestone dealer for mounting and balance and installation. They took off one front and one rear wheel and placed the new wheels on the hubs to see how they fit. Eventhough the wheels did'nt rub, they said that there was not enough clearance from the rim to the shock in the front and the rim the the plastic in the rear. They would not mount the tires because they said that this setup would not fit. They recommended that I should only place 8.5" in the rear and find 8" in the front (which I have not seen anywhere on this site).
Is the Firestone mechanic being too cautious, or is there a chance that I would need spacers or something else to make this work. Last choice would be to return everything and start over.
Please give me your opinion....
Old Jun 15, 2008 | 09:04 PM
reserved's Avatar
clk 500 (wifey's); 350Z roadster (daily driver); 350Z coupe (track car)
Even with such a lot of offset in the rear, it does not surprise me that you may have issues. IMHO a big part of the problem is the tires. Eagle F1's have a very "square" shoulder.
Here is my experience
https://mbworld.org/forums/wheels-tires-suspension-brakes-forum/243555-what-reasonable-amount-camber.html
Old Jun 15, 2008 | 10:32 PM
JuicedMB's Avatar
https://mbworld.org/forums/showthread.php?t=243555
They didn't mount the tires, they only mounted the rims.......
Old Jun 16, 2008 | 12:16 PM
reserved's Avatar
Oops! Sorry, I misunderstood
While I am far from being an authority on this stuff, I would have to agree with you. With those sizes and offsets, these wheels should fit.
Unfortunately' you may only know for sure if you go ahead and have the tires mounted, so you can assess things with the car sitting on the ground rather than on a lift.
Again though, to maximize your chance of success, I would NOT use those F1's.
Hope things work out OK.
Old Jun 16, 2008 | 12:39 PM
kiamcoj's Avatar
2012 CLS63
Your offsets and widths are correct. Unless you are really low you shouldn't have a problem. Like reserved said mount the tires and try em on. Most of us are lowered with the same offsets and widths and the wheels work perfectly. Good luck.
Old Jun 16, 2008 | 01:22 PM
JuicedMB's Avatar
I think that I'm going to mount them and try them. I will probably have the tire shop mount and balance the tires and I will install them myself on the car. It seems as though the Firestone place I originally went doesn't have enough experience with plus size mounting. The wheel mechanic kept telling me that he was experienced with MBs and that the 19x8.5 was the right size for the rear and said I should get 19x8 for the front. Of course he also said that 19s should not be mounted on the clk anyway and that 18 were the largest I should try. This should have told me how experienced he really was...
I will let you all know how it goes... Thanks for your help.....
Old Jun 16, 2008 | 01:42 PM
unitfreebie's Avatar
2006 CLK 350 Fog City, CA, USA
Exclamation Yes... it's French, but ....
Personally, I would not put anything but Michelins on my car... even if it is a French company... they do make the best tires!!!
Old Jun 21, 2008 | 09:04 PM
JuicedMB's Avatar
Well, I had the tires mounted and balanced on the wheels and installed the wheels today. They fit great, no problem with rubbing at all. Now, all I need is to lower it. I haven't decided between Eibach or H&R.
My fiasco with Firestone shows that many tire store focus more on the standard run or the mill setups. Their so called "MB expert" was a loser.
Anyway, thanks for your help.....
Old Jun 21, 2008 | 10:02 PM
kiamcoj's Avatar
2012 CLS63
Were your MB Experts...lol
Sounds great, now you know what you have to do now!!! PICSSSSSSS!!!!!
Jon
Old Jun 23, 2008 | 09:44 PM
JuicedMB's Avatar
Here is the before....
Here is the after....
Definitely needs to be lowered......
Old Jun 24, 2008 | 07:05 AM
trikoid's Avatar
09CLK550Cab 61k miles
WOW, those look way better! Changed it from a boring passenger car to something sporty.
Personally, the diameter is too big for my tastes, but it definitely works.
Old Jun 24, 2008 | 01:47 PM
How's the ride in terms of quietness and handling compared to the stock 17's?
Old Jun 24, 2008 | 03:00 PM
kiamcoj's Avatar
2012 CLS63
Looks great!
Time for a lip spoiler...
Old Jun 24, 2008 | 08:13 PM
JuicedMB's Avatar
Over bumpy roads you can notice a difference, but it is not annoying by any means. The road noise is actually the same or less than the stock 16"s (Continentals).
I like to feel of the wheels when cornering also. The rear seems to hold the line better now.....
Old Jun 25, 2008 | 12:17 PM
ark1tech's Avatar
2003 CLK 500
Those wheels look really nice. If you don't mind saying, how much did you play for the wheels?
Old Jun 25, 2008 | 10:18 PM
JuicedMB's Avatar
About $850 including shipping.....
Old Jun 26, 2008 | 05:29 AM
Vabene7's Avatar
Garage Temporarily Empty
Attachment 133589
Attachment 133590
Attachment 133591
Looks great.
When you lower the car, you will notice such a difference with it's look..... There is so much more of an aggressive stance when it's down and inch and a half.
I used Eibach, but I went with them because I got a deal on the price. Either one you choose will work out for you. It's just personal preference.
-Chris
