strange clicking from dash on start up???
Old Sep 23, 2008 | 12:25 PM
jonnyoutram's Avatar
merc 126 500 sec 1984
hi, my mother has a 2002 new shape clk320. when she starts the car there is a click of about 1 second intervals coming from behind the glove box area, or somewhere in the dash. i have a feeling its something to do with the climate control??? some times the clicking will last different lengths of time.
it sounds like a plastic cog slipping as if its trying to turn something that's reaching the end of its travel.
mum thinks its somebody stuck in there trying to get out and she is getting scared???
any ideas anyone?
Old Sep 23, 2008 | 02:50 PM
oorjim's Avatar
2003 clk 320
Could it be the CD changer as that is in the glove box? Just a thought.
Jim
Old Sep 23, 2008 | 04:52 PM
Jim
i dont think do its too loud and i have already tried taking the casset out and it still made the noise... it could be in the middle of the dash im not sure?
Old Sep 23, 2008 | 08:05 PM
Supafly's Avatar
I drive the racism out of BadDebt. ;)
Im betting money on a step motor malfunction... a broken arm on the motor will make a click---click---click noise for a few seconds as the motor turns and the arm turning and hitting the stopper.
theres a few behind the dash, and they control all the climate control flaps.
i had this problem before, and i pulled my entire dash to figure it out....fix it yourself with a bit of DIY and some ingenous thinking and it will never break again. lol
going to mb and you will end up with a bill of about 1200 bucks.
Old Sep 23, 2008 | 10:23 PM
Discgolfer74's Avatar
2003 CLK500
Yeah, its a broken lever or something like that, in the heater box. It controls the vent direction (vent/floor). Mine does it, but it stops after a little while. I guess the replacement part is around $100, but its about 8 hours in labor to do it. My MB guy quoted me something in the ballpark of $1200 to repair. I told him that I'll just turn the music up if it gets on my nerves. It started about a month ago for me, and now, I hardly even notice it.
Good luck!
Old Sep 23, 2008 | 10:55 PM
coin's Avatar
'06 CLK500
It's a common issue which in my case was replaced under the warranty.
Old Sep 23, 2008 | 11:34 PM
thanks everyone! does anyone have any idea how to get to this"heater box" ?? do i take the glove box out?? is there a guide anywhere on the forum?
Old Sep 24, 2008 | 10:03 AM
2003 CLK500
From what I understand, the dash has to be completely removed to get to it. That's why the labor is so extensive. I'm not brave enough to do it myself.
Old Sep 24, 2008 | 10:10 PM
thanks for the heads up! how annoying... i will have to give it a go one day!
if anyone has removed a dash b4 i would really appreciate any pointers.
for example.. where any hidden screws or bolts are??
thanks
Old Sep 26, 2008 | 08:03 PM
mleskovar's Avatar
'17 Jaguar XF
Originally Posted by jonnyoutram
...if anyone has removed a dash b4 i would really appreciate any pointers.)
This symptom is consistent with the stepper motor/flap actuator breaking in the C class. A common failure. STFF the C Class forum for 'stepper motor' and you'll find several DIY posts. I don't know how similar or different the two cars are designed but it will give you a start of what to look for and be careful of. LOTS of pieces have to come off to get to the part in the C.
Old Oct 15, 2008 | 05:26 PM
ark1tech's Avatar
2003 CLK 500
Same problem
I have the exact same problem. The noise in my car is coming from somewhere behind the steering wheel. It seems like $1,200 is alot to get this problem fixed!
Old Oct 15, 2008 | 11:07 PM
2003 CLK500
It is for me... I can live with 30 seconds of clicking.
Old Oct 16, 2008 | 03:45 AM
FLYNGUN's Avatar
CLS 63 S AMG
I have the same clicking noise problem, it just started about a month ago. I read through this post in the C forum :https://mbworld.org/forums/showth...ard+removi ng
Read the DIY info posted by Racin Fool... it's amazing! This guy took the time to go step by step on the process and Liveniceguy posted all of the pics. It was like reading an aircraft T.O.!
Is there anyone out there that has the same type of techincal info for this process for W209's?
Kudos to Racin Fool and Liveniceguy for such a great post... wish it was relevant for the CLK-55 or W209 forum though
Any takers???
Old Oct 16, 2008 | 01:22 PM
Supafly's Avatar
Any takers???
the c-class w203 is almost identical to the CLK w209...
i actually used his guide to tear out my dash to replace my step motors.
Old Oct 18, 2008 | 02:36 PM
mleskovar's Avatar
'17 Jaguar XF
If you decide to do it yourself make sure you replace both footwell flap actuator arms. It requires you to take out the glove box side as well but it doesn't take long once you have it down that far.
