Ipod hookup
Then It will charge the Ipod and you can use the Multifunction Steering Wheel Controls....Also it will show up in the Instrument cluster
You may need to check whether you can setup the AUX input. I think that is the best solution.
If not, looks like you have to use the FM transmitter.
Once you plug your cable into the jack, press the "radio" button on your COMMAND system, and then press the "AUX" button. After that, you're in business.
