Running 5mm spacers on a 19x9.5 et40mm for the rears
I am planning to get a set of wheels and the size is 19x8 et30mm and 19x9.5 et40mm. I have been doing my searches and it seems that 19x8 with a 30mm offset works. However, the rears should be 35mm and what i will get has a 40mm offset. My question is, I should get a 5mm spacer to get to 35mm right? or should i go 7mm? secondly, do i need to change the bolts for the rears?
Front:
7.5, ET 35
7.5, ET 37
Rear:
8.5, ET 30
8.5, ET 34
can someone confirm with me that i can use spacers for these. i have done my calculations and from what the common agreement, 19x8.5 et32mm fits well. to make the outside edge at par with the 8.5 wheel, i can add a 5mm hubcentric spacer to make it et25 which makes the outside edge stick out 18mm like an 8.5 width wheel. true?
i have not tried the rear ones yet. just trying to make sure these wheels fit. they are axis matrix which i got for cheap brand new at axis here in socal.
3mm spacers instead of 5mm?
Width of the tires may all say the same, but in reality some tires are wider than others.
So when you lower your car, you might find that there may be some rubbing along the edge of the tires.
