Problems when jacking the car.... help needed
I'm trying to lift all 4 corners on 4 jack stand ( to reduce the pressure on the suspension and tires )
I looked under the car near front, to lift the hole front
to put 2 jack stand in the front first (near the wheels) std jacking pointsBut I can't find a good hard spot to lift
same problem for the rear
anyone can help me help here?
Tools I have for the job : one 2.5 ton low jack lift (nascar lift
I just wanted to speak to you on the subject of storing your cars.
Do you leave them for the winter months without driving them?
Or do you take them out briefly to keep them moving?
Or do you have a set of rolling roads that you use in the garage to run them in the winter?
I'm curious because I, too, do not wish to drive my AMG in the winter.
It's tucked away in the garage away from the elements (well, apart from cold, unfortunately) but I didn't really like the thought of it standing there indefinately.
I am aiming to take it out whenever I get the chance (basically when it's clear & dry), but I don't think that's likely to be often.
Is it ok to just leave cars standing for weeks on end without drivng them?
I'm worried about carbon build up or seizing etc.
The modern synthetics work so well at avoiding any engine problems.
Thanks for your input.
Much appreciated.
So, is it ok to let the car warm up without driving it?
I always thought it was advised to start driving it as soon as possible and let it warm up while in motion.
I'm quite happy to let it warm up will it sits in the garage, I just didn't want to risk damaging it.
I will also do as you say and move the car to keep wheel bearings coated.
Man, I hate this weather.
Just noticed you Avatar etc..
E63.
Well done, old bean!
annually, my precaution steps are as follows:
-top up fuel to capacity
-throw a box of baking soda in the car to soak up any moisture or smell
-throw car on jackstands if i have the time for it
-buy a trickle charger for your battery
-wipe enginebay down with a clean MF cloth and some rubber/plastic protectant (i like the look of a clean bay just before i get her ready for spring)
i read somewhere that if you store your car, and start it once in awhile but not driving it, does more harm than not starting it at all...something about oil and moisture building up in the chambers.
Thanks for your input, bud.
I reckon I'll get a trickle charger for the battery.
Still not sure whether to let it warm up at a standstill.
It's just that I don't like the thought of it just sitting there.
I'll get some baking soda too.
As for wiping down the engine bay..... man, you obviously don't know me.
LOL
Thanks again bud.
the jack to lift the car?
(I just wanna be carefull under there )thanks
And the rear differential... point to lift? Pic ? Is it near the AMG oil cooler?
Thank
I need to lift the car soon.
It's been stored for 1 month :S
BTW : I use a "battery tender" to make sure the battery stay at a good
stady voltage. ( Just plug the tender in the wall and connect to the 2
battery point)
-I full the gas tank
-and I put some gas stabiliser.
-Usully I start the car for 10 mins every 2 to 3 weeks
-and lift the 4 corners of the car, for tire flat spot and suspension
I would then move the jack to lift the rear of the car under the diff as shown, and place the other 2 jack stands in the pads at the rear sides of the car.
By jacking the car up and taking the load off the suspension, you will also be twisting the bushes on the shocks slightly.
You could prop the car up on axle stands on the suspension arms. This would take the load off the tyres. But will obviously keep load on the shocks and springs. But will, however, prevent twisting your bushes too much.
We've had some pretty wintery weather over the last few weeks.
I didn't like the thought of keeping it standing still for weeks on end.
Luckily, I did find 2 days in the last 6 weeks to drive it.
Nice dry days with minimal dampness.
After standing in the garage for 3 weeks, the car started fine and the tyre PSI had only dropped by 2.
Battery was cool too.
It actually had 2 volts more in it than when I last drove it?! lol
Car drove well.
Filled the tank up again and parked it up.
3 weeks later, I did the same.
Anyway, what I'm saying is, if you're garaging your car for about a month, I don't think there's really too much to worry about.
If you're running low-pro tyres, flat spots shouldn't really be an issue either.
My tyres were fine.
Low-pro tyres are, as you know, have little flex. Not nearly enough flex or depth to cause flat spots as easily as big, soft bouncy tyres.
It was good to get the car out. I think it appreciated it too.
I don't feel quite so paranoid about leaving it sitting for a few weeks now.
Anyway, just wanted to share this with you.
But there is no way any jack will go under the front bumper !
I guess I have to lift the front side left wheel first.
then goo under the front bumper... hummm ok
thanks
Andy
same here buddy.
