Rear Bilstein PSS9 Coilover Kit for sale
Old May 20, 2010 | 06:47 PM
C-three-twenty's Avatar
01 C320 Lorinser Ed.
Used Rear Bilstein PSS9 Coilover Kit for sale
Approximately 50K miles on springs. Includes everything you need for the rear coilovers. (Rear Springs, Brand New Spring Hats, Adjustable Coilover Assembly, Two Coilover Wrenches, Nuts and Bolts.) No shocks included. Easy to install yourself and easy to adjust height. In perfect working condition.
This is actually the prototype that Bilstein designed for Carlsson, but it was never produced by Carlsson and Bilstein ended coming out with the kit instead. Kit was purchased in Germany from Carlsson.
$200 shipped
Paypal preferred.
email for more info at dustineck@hotmail.com
Selling because I just replaced them with a new Bilstein PSS9 Kit.
Attached Thumbnails Rear Bilstein PSS9 Coilover Kit for sale-img00091-20100520-1523.jpg   Rear Bilstein PSS9 Coilover Kit for sale-img00092-20100520-1523.jpg   Rear Bilstein PSS9 Coilover Kit for sale-img00095-20100520-1524.jpg   Rear Bilstein PSS9 Coilover Kit for sale-img00093-20100520-1523.jpg   Rear Bilstein PSS9 Coilover Kit for sale-img00094-20100520-1523.jpg
Old May 20, 2010 | 07:59 PM
dynomite05's Avatar
04 CLK 320 > CLK32K
You selling the fronts?
Old May 20, 2010 | 08:45 PM
No. Just the backs. The front coilovers are built into the shock. I replaced mine because the shocks were blown.
You could always use this with your current lowering setup and install the coilovers for some added adjustability.
Old May 20, 2010 | 08:47 PM
dynomite05's Avatar
04 CLK 320 > CLK32K
I'm good with the rear, was looking for front. Thank anyway and GL with the sale
Old May 20, 2010 | 11:02 PM
M-bENZ's Avatar
Corrolla
So those kit can be used with any standard shocks or ??? even with a stock shock ? yea ? lol
Andy
Old May 21, 2010 | 12:08 AM
You should be able to use it with any aftermarket or stock shock. The coilover kit basically sits under the spring and adjusts up and down. The spring is completely separate from the shock so there shouldn't be any problems using whatever shocks you have. You will probably have a better ride quality with an aftermarket shock. Let me know if you are interested.
Old May 21, 2010 | 01:17 AM
Klinh's Avatar
C63s Cabriolet, BMW M4, Civic
I wouldn't do it even if it for free. Even though most springs look pretty much the same but there is a big different between them, it called "spring rate" measured in lbs.
Old May 21, 2010 | 01:32 AM
M-bENZ's Avatar
Corrolla
hmm...interesting.
Andy-
Old May 21, 2010 | 01:53 AM
michaelnovikov's Avatar
CLK
Agreed, i would recommend doing more research
Old May 21, 2010 | 03:01 AM
pinoytm's Avatar
-=[CLK 500 2006]=- -=[Dodge Ram 2001]=- -=[Kawasaki Ninja 636 2005]=-
it means.... OMG FAIL! NO FAT CHICKS PLEASE! LOL
was that the right sticker? lol
hmm...interesting.
Andy-
Old May 21, 2010 | 08:39 AM
You are saying that the spring rate is the factor that makes the difference so no matter what shock you put, the ride height would be consistent, no matter if it was a stiff shock or not.
This is the same as if you put a lowering spring on a stock shock or on an aftermarket shock, the ride height doesn't change much, just the ride quality.
Please let me know if I am wrong here. Thanks.
Old May 21, 2010 | 03:23 PM
Klinh's Avatar
I'm saying that coilover springs are shorter then aftermarket spring. And because it shorter with less suspension travel, the springs load rating are much higher and much much stiffer. These type of springs is fine if you combined it with an adjustable rebound and compression damper struts/shock. But these type of springs would not work specially with stock struts/shock. In general, you want to go with stiffer struts/shocks to control the springs not with stiffer springs and have a weak stock struts/shocks that can't control the springs. Plus, springs are designed to go in set (front and rear). On factory cars, the spring rate are based on the weight of the car. This is why they designed one set for the V6 and V8 engine due to the weight different. I know for a facts that the W209 stock struts/shocks can't handle the aftermarket springs even with Eibach springs known to be the less stiff then any others.
