Is my trans. going bad or a sensor problem? Need help please!
something weird happened today.
I was driving and my car seemed to be stuck in second gear.
Putting the car in Park and back to drive didnt fix it but shutting the car off and back on fixed it.
My car has 64.000 miles so im not sure if this is a common problem.
Thanks for any help!
It a 2006 model, if you haven't done the tranny flush services yet then you're 26K miles too late.
So whats my best solution you think?
I have extended warranty on my car which covers everything including a bad transmission all i pay is $100.
Thanks for your help Klinh
Last questions would be: Even though i have no Check engine light turned on would the dealer still be able to read faulty codes or no?
Its gonna cost me $120/h for them to see it lmao.
Hopefully my extendet warranty will cover diagnosing as well, if not there goes my money that i was goin to use to buy the CF front lip.
I will definetely keep you guys posted though...
$2100 i was like HOLY ****. Problem was a valve and a bad speed sensor.
Gladly it will be covered by my third party extended warranty.
I think its worth the $4000 i paid for it. To any new owners take note.
Thanks for all the help guys i will give more details when i get a report from them and write all parts and stuff.
Also by changing that i am getting new transmission oil put in as well so i guess that helped
I will be sucked without my car for 3 days so they gave a courtesy one a 2008 C300. HATE IT lol
Run down of what they did and what the problem was:
64803 Valve body performed short test. Code in ETC 2767- the signal from sensor Y3\8N2 is not available. Remedy is to replace the electronic hydraulic unit. Replaced EHS, programmed and codes to vehicle. Cleared all codes. Fill and set fluid level. Performed transmission adaptation.
Diag Perform Diagnosis Tests - 35CPM - $124.95
70 Misc. Transmission repairs - 35CPM - $402.50
1 220-270-27-06 CTRR. UNIT E - $1250.00
1 221-277-01-95 OIL FILTER - $36.00
1 220-271-03-80 GASKET - $12.00
6 004-990-35-12 SCREW - $0.90
6 001-989-68-03-10 TRANSMISSION - $17.50
10 004-990-75-12 SCREW W COLL - $0.90
So that is PARTS :1417.40 LABOR - $527 plus all the taxes and env. fees adds up to that
I'm trying to see the parts online but cant find them all but yah you guys can a get a general idea of what your problem might be if you see the same signs.
Now gladly i can still afford to get the front lip and finally my DDM 35W fog light HID kit just came (3 weeks for shipping lmao) so i will be looking forward to tha nad post some pics as well.
Take car guys and hope this never happens to anybody in here
Im of
again
Did you find a solution? Any hints on the cause of the problem?
Please help.
https://mbworld.org/forums/showthrea...84#post5148984
