LIST OF PARTS & PART #'S
Rating: Thread Rating: 4 votes, 5.00 average.
Old 03-10-2013, 03:58 PM
  #276
Dimitri's Avatar
2014 E350 Coupe 4Matic
Hi guys,
Do you know if this has a part number or its all door assembly? Just wanted to check because want to try to order them in red color
https://www.dropbox.com/s/yhg36cv0e0h7q9r/door.jpg
Old 11-19-2013, 07:23 PM
  #277
ricardovasco's Avatar
CLK 500
Hi all. Do you guys know if the part 2098201664 ( tail light) is the red/white color or if it is red/smoked( amg style)?
Regards
Ricardo
Old 06-15-2014, 08:09 PM
  #278
MacVidMB-V8's Avatar
W209, W124
Comand System Part Numbers
For 2005-7 cars, you can use A 209 870 2089 (has "SERV" button)
For 2008-9 cars you can use A 209 820 7889 ( has "SYS" button, I have one for sale in Classifieds)
There are additional part numbers but these two I have held in my hand and used in a 2005 CLK. The later model with "SYS" button does not allow you to set time when installed in a 2005-7 car.
I do not know what happens when older model is used in newer car.
On the "SERV" system, you access the "ENGINEERING MODE" by hitting "OK", then "7" then "MUTE". I was unable to find a way to access it in "SYS" model. If someone knows, please PM me and I will add to this post.
Also note, when I first installed the 2008 model in my 2005 I had sound function but no instrument panel integration until coded. When I installed the proper 2005-7 "SERV" model I gained proper clock support but because the unit had been used in a vehicle with different MOST setup, resulting in silence until I used STAR to reset MOST bus. I wish I had tried the "RESET" button on COmand but I don't think it would have solved issue. So, if you do a retrofit, you may or may not have working audio. May very well require STAR system.
Old 02-02-2015, 09:39 PM
  #279
TheNoble's Avatar
2003 CLK320
PURGE CONTROL VALVE- Vapor Canister - VALVE
Part Number 0004767032
https://www.parts.com/index.cfm?fuse...-CONTROL-VALVE
Old 09-22-2015, 12:59 AM
  #280
senna1@ihug.co.'s Avatar
AMG CLK63
Under body panels
I am looking for a front lower left guard liner for my right hand drive 2006 AMG CLK63 passenger side can anyone help me track one down are there after market ones
Old 04-06-2016, 11:07 AM
  #281
zuzu_pali's Avatar
2004 clk500
hey if any one is selling the front sam module or fuse box cover . in need of one
Old 06-14-2016, 06:03 PM
  #282
AMG CLK63
hi where can i purchase passenger side front inner fender plastic guard for my AMG CLK63 2006 Model?
Old 03-30-2017, 02:19 AM
  #283
Khan 55's Avatar
2004 CLK55 AMG W209
http://www.mbpartsworld.com/showAsse...rimLevel=20538
Try that link. Part number 165 is for a CLK63. You could also find the part on Pelican parts.Alternatively visit this site http://www.autopartswarehouse.com and look your car up. You should find it. They are quite cheap there but availability is the issue.
Old 06-20-2018, 03:42 PM
  #284
Hk91308's Avatar
04' CLK, 09 997.2 GTS, 22 992 C4S
Originally Posted by dynomite05
I came across a parts list today that lists every part and part # on the w209 from 03-08. If anybody needs any part #'s let me know
CLK320 03-05 w/ Sport Pkg 2094920214
wo/ Sport Pkg 2094920114
CLk350 06- 2094920214
CLK500 03-06 2094920214
CLK550 07- Only sold with muffler
CLK55 03-06 2094920114
CLK63 Only sold with muffler
‘’my 04’ CLK glove box latch is now broken where it doesn’t keep the glovebox closed etc, would you have a part number for this and any instructions to remove and replace it?
Old 09-17-2018, 09:30 AM
  #285
Tuck G's Avatar
2006 CLK 350 cabrio
I have a 2006 CLK 350 convertable ...I am having a hell of a time finding the part# for the trunk partition limit switch. If anyone can help me it would be greatly appreciated . Thanks in advance ...
Old 09-17-2018, 10:24 PM
  #286
MBworld Guru
Rudeney's Avatar
Received 1,004 Likes on 872 Posts
NO LONGER ACTIVE
I believe that I have most all of the soft top hydraulic and electrical parts listed here:
http://benzbits.com/w209/soft_top/W2...gnosticAid.pdf
You will find that partition limit switch (S89/3) and its part number on page 3.
Old 09-18-2018, 09:56 PM
  #287
Tuck G's Avatar
2006 CLK 350 cabrio
Talking
Thank you Rudeney. That part list was exactly what I was looking for. My headache just went away..
Old 04-10-2021, 02:58 AM
  #288
crazy00c230k's Avatar
2000 c230 kompressor special edition, 2012 E550 coupe (sold), 2017 C63 sedan (sold), 2018 C63S Coupe
Did the full replacement of hydraulic cylinders on my mom's 05 CLK320 cab recently, here are a couple of PNs I had a tough-ish time tracking down.
Clips for the hinge pins - 0009944160, they're listed as automatic transmission clips, but can confirm they're the same.
Cover for the emergency latch lock/unlock bolt for the roof - 1709880035XXXX, where the Xs will be a color code. If you search one of those OEM parts websites for the core number without the Xs you should get a list of the colors with their specific PNs. Mine was 17098800357E94 (grey).
Old 08-01-2022, 11:15 AM
  #289
Tessa Sag's Avatar
2006 CLK 350
I thought it would be good to have as many part #'s in one thread as we can. This is a list I started making a while back. I obviously don't have everything so please feel free to add whatever you think might be helpful. Hopefully we could make this a "ONE STOP" reference thread. All part #'s were checked, please let me know if any of them do not work.
*MODS, HOW ABOUT AT LEAST ONE STICKY FOR THE W209 FORUM*
  1. HOOD EMBLEM 1298880116
  2. RAIN SENSOR HOOD GRILLE 2038801905 (PM ME FOR COLOR DETAILS)
  3. MB WEDGE (TOOL) 110589035900
  4. 3RD BRAKE LIGHT 2098201056
  5. LICENSE PLATE LENS 2308200166
  6. G. DAIMLER LABEL 06-10 (CLEAR) 0045847338
  7. GRILLE STAR 2158880186
  8. GRILLE STAR (DISTRONIC) 2158880086
  9. JACK PAD 2039970186
  10. TRUNK BUMPERS (INSIDE LID) 2037500097
  11. TRUNK STAR EMBLEM 2097580058
  12. TRUNK LID LOCK 1717500085
  13. PRE-FACELIFT AMG BUMPER FRAME 2098850065
  14. 05 CLK 55 REAR BUMPER CUT-OUT 2098854025
  15. C55 SPARE TIRE WELL 209 610 05 75
  16. WIPERS (PAIR) 2038201845
  • W204 C-CLASS TIPS
  1. LFT TIP 2044906327
  2. RT TIP 2044906427
  • 06 E55 AIRBOX CONVERSION
  1. ENGINE COVER 1130100967
  2. LFT AIR INLET 1130942282
  3. RT AIR INLET 1130942182
  4. KEVLAR INLET LFT 2730900182
  5. KEVLAR INLET RT 2730900082
  6. LFT AIR CLEANER 1130900501
  7. RT AIR CLEANER 1130900601
  8. REAR INTAKE ASSY 1130900129
  • 03-05 FRONT FENDER LINER/SHEILD
  1. DRIVER 2098840322
  2. PASSENGER 2098840422
  • 06-09 FRONT FENDER LINER/SHEILD
  1. DRIVER 2098841322
  2. PASSENGER 2098841422
  • 03-05 COMPLETE GRILLE ASSY 4 SLAT
  1. W/ DIST BLACK 20988003839040
  2. W/ DIST GRAY 20988003837246
  3. W/O DIST BLACK 20988001839040
  4. W/O DIST GRAY 20988001237246
  • 06-09 COMPLETE GRILLE ASSY 3 SLAT
  1. W/ DIST BLACK 20988202239040
  2. W/ DIST GRAY 20988002237246
  3. W/O DIST BLACK 20988001239040
  • 03-05 AMG FRONT BUMPER GRILLES
  1. CENTER GRILLE 2098850053
  2. LFT GRILLE 2098850153
  3. RT GRILLE 2098850253
  4. CLIPS FOR GRILLES 0029885181
  • 06-09 AMG FRONT BUMPER GRILLES
  1. CENTER GRILLE 2098850553
  2. LFT GRILLE 2098850353
  3. RT GRILLE 2098850453
  4. CLIPS FOR GRILLES 0039947945
  • 03-05 AMG FOG LIGHT ASSY
  1. LFT 2308200356
  2. RT 2308200456
  • 06-09 AMG FOG LIGHT ASSY
  1. LFT 2098200756
  2. RT 2098200856
  • AMG SPORT PEDALS
  1. GAS 1703000004
  2. BRAKE PEDAL 1702900182
  3. PARKING BRAKE 2034300084
  • SPRING PADS
  1. 5MM 2103250184
  2. 9MM
  3. 13MM
  4. 17MM
  • MIRROR TURN SIGNALS
  1. LFT 2308200721
  2. RT 2308200821
  • 06-09 TAIL LIGHTS ELEGANCE
  1. LFT 2098201364
  2. RT 2098201464
  • 06-09 TAIL LIGHTS AVANTGARDE
  1. LFT 2098201564
  2. RT 2098201664
  • HEADLIGHT REPAIR KIT
  1. LFT 2098201114
  2. RT 2098201214
  • CLK 63 BLACK SERIES
  1. FRONT SWAY BAR 2093200410
  2. REAR SWAY BAR 2093260365
  3. REAR SWAY BUSHINGS 2033260881
  4. FRONT STRUT BRACE 2093250165
  5. REAR STRUT BRACE 2093200190
  6. FRONT CALIPER LFT 0034206783
  7. FRONT CALIPER RT 0034206883
  8. REAR CALIPER LFT 0034202983
  9. REAR CALIPER RT 0034203083
  10. FRONT ROTOR 2094210112
  11. REAR ROTOR 1714230212
  12. BRAKE PADS FRONT 0054203920
  13. BRAKE PADS REAR 0054204120
  14. SPOILER 2097900588
  • CLK63
  1. DOOR SILL LFT 20968009359B51
  2. DOOR SILL RT 20968006359B51
  3. SPARE TIRE WELL 2096100575
  4. REAR BUMPER CUT-OUT 2098856125
  5. REAR SHOCK 2033264400
  6. FRONT SHOCK 2093203730
  7. HEADER LFT 1561400109
  8. HEADER RT 1561400009
Hello!
Does anyone have the part number for the 2006 CLK350 Soft Top Manual Override Wrench?
Local Dealer says 129.581.0066 (Expensive!!!), but the MB Parts web site says that it is not for 2006 (says 1990-2002). Do I really need this part or will a regular 6mm Allen wrench and an open wrench (What size?) will do?
I think it may be just a 6mm Hex Allen Wrench on one side, but do not know what size the either open-wrens is or whether is it straight or curved (there seem to be at least two different shapes).
Thank you!
You have already rated this thread Rating: Thread Rating: 4 votes, 5.00 average.
Quick Reply: LIST OF PARTS & PART #'S
