DIY: Remove and replace valve cover gaskets and spark plugs
Old Mar 26, 2020 | 09:53 AM
  #201
776westfield's Avatar
2005 CLK500 Convertible
Thank you for the guidance. I just want to make sure those are correct torque specs: breather cover bolts 4 Nm; ignition coil bolts 8 Nm; valve cover bolts 9 Nm. Please confirm.
Old Mar 28, 2020 | 02:41 PM
  #202
I received all MB parts to change the valve cover gasket and reseal the breather covers. I have one more question regarding the sealer A 003 989 98 20 10. In order to apply it correctly with 2 mm diameter, where should I cut the tip? It looks like there is a slight indentation about 13 mm from the end of the tip. Is this where it should be cut?
Old Mar 28, 2020 | 03:12 PM
  #203
Mackhack's Avatar
Doesn’t really matter as you control it by the pressure. If I’m doubt cut it open and try it on a piece of cardboard first and squeeze 1-2 cm out and see how it goes. If you feel you have to push too hard cut it a bit more to increase the size of the hole in the tip. That’s how I do it.
Old Apr 3, 2020 | 03:41 PM
  #204
While putting the new houses together, I noticed that the connector A 112-018-02-09 has a partial obstruction inside. It's a piece of rubber that flops inside partially blocking air to go through (see picture). Is that normal?
Old Apr 13, 2020 | 05:03 PM
  #205
Thank you for the guidance. I completed the job. Replaced all breather hoses and connectors, reattached both breather covers using MB sealer, and replaced both valve cover gaskets. So far all good. To remove old sealer I used MB 001-986-71-71-09 Cleaning Agent. Works great. I ordered all parts from mbpartscenter.com
Old Aug 13, 2020 | 04:22 PM
  #206
Nick Louis's Avatar
2005 CLK 500
I need to replace the spark plug wires for cylinder 3. Does anyone know the part number for the individual wires?
Old Aug 13, 2020 | 04:49 PM
  #207
dzmitry's Avatar
2023 E450 AT, 1996 S420, (sold) 2004 CLK320 Convertible (v8, 6 speed)
In Mercedes parts catalog they are marked as 3A (part # 112-150-02-18) and 3B (part # 112-150-01-18)
Old Aug 14, 2020 | 05:03 PM
  #208
Nick Louis's Avatar
2005 CLK 500
Are the lengths 245mm and 265mm?
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
You have already rated this thread Rating: Thread Rating: 2 votes, 4.50 average.
