any 1 use nt-01 nitto tires (also some drag tire info)
Old Oct 6, 2010 | 08:01 PM
buffyclk500's Avatar
clk500
i am looking 4 a race tire
the info i have now is
nitto nt-01
245/50-16
hight: 25.47
nitto 555r
245/50-16 $140-shipped
hight: 25.67
weight:26lb
bfgoodrich T/A drag
255/50-16 $168-shipped
hight: 26.1
weight:26lb
hoosier dot drag radials
255/50-16 $204.98-shipped
hight:26.4
weight:22lb
goodyear eagle ss
255/50-16 $194.98-shipped
hight:26.1
weight:24.2lb
M/T drag street
255?50-16 $194.97-shipped
hight:26.1
weight:29lb
Now for my ??s
i found some used nt-01 for a good price but will they hold up for drag racing
has any 1 used them
Old Oct 6, 2010 | 10:35 PM
blackbenzz's Avatar
haters crazy
How much power are you making and will these tires be used for only drag racing?
Old Oct 6, 2010 | 11:57 PM
clk500
they will b 4 drag and track racing
320rwtq and 300rwhp around there
Old Oct 7, 2010 | 12:15 AM
blackbenzz's Avatar
haters crazy
Drag and road racing? Then you shouldn't be looking at drag radials. Try the Toyo R888's
Old Oct 12, 2010 | 01:40 AM
AzCamel's Avatar
10 GLK350/ 15 Accord/ 94 Supra Turbo
you have two different purpose, you need two different type of tire.
For road racing try the ones recommended by blackbenzz, the toyo R888
For drag you dont need anything as drastic as the M/T Et Street, Hoosiers, etc... for you HP, those tires wont do you any good, you wont be able to use them effectively anyways. The Nittos Nt01, BF T/A, or 555R will be more then enough for you. Also note that "performance/drag" tires will loose their effective life relatively soon, you might still have tread but the ability of the tires to grip might be gone before the tread wears out.
A quality set of performance summer tires will meet your needs just fine, your car is heavy and the HP is not that high for you to require such a drastic tire compound.
Old Oct 12, 2010 | 01:50 AM
clk500
well i got the the nt-01 and the r on my rims but i will b testing them 2marrow and trying 2 get ready 4 friday
but so far tires and rims r at 40lb
that is rims tires and 38psi so big diff from my old 70lb set up so we will see
Old Oct 12, 2010 | 06:37 AM
dynomite05's Avatar
04 CLK 320 > CLK32K
GL, let us know how it turns out
Old Oct 13, 2010 | 10:00 PM
clk500
got the tires and did some testing
40 roll hooked up great
20 roll hooked up good
from a dig little spin
that was all with 38psi
Old Oct 16, 2010 | 02:09 AM
clk500
well the tires r ok
but could not hook up
only had 4 runs and could not test them very good
