car stalled for no reason!! why!!!?!??!
2000 Volvo S40, 2006 Hummer H3, 2008 CLK550
i was driving today and at a red light...then i feel the engine hesitate
and the engine shuts off...and ALL the warning lights on my dash light up!! i had to restart the car then it worked fine...
my car has been hesitating ever since i installed the K&N air filters a year ago...
i think it might be the MAF
anybody with this problem???
'05 C200K SS, '05 Kleemann CLK500K, '08 Hummer H3 & '92 Z34 5sp (track car in Canada)
K&N filters don't have the nick-name 'Gravel-Guards' without reason. They flow a heck of a lot of air but do a piis poor job at filtering. After using a K&N cone filter for 6 months back in Canada, the inside of the air intake tube was black as was the intake manifold and MAF. I have never used them daily after that, only for the track or race nights.
+1 with Andy, take the MAF out and clean it with no-residue electrical contact cleaner and go back to paper filters.
All you have to do is take the MAF unit out, clean it up spotless and pop it back in - then check it in 6 months, it and the casing will be covered in crud. Do the same with a paper filter and the difference is night and day. If you're going to use them and want to protect the engine, keep them clean and use minimal amounts of oil. For the extra 1 or 2 peak HP vs. by-pass contaminents I've decided not to use them daily.
If you're happy with them (as I was years ago), good on you, just keep them clean.
I dont drive daily thats Y lolz. The car is the weekend toy
or even if its a daily drive I can take it out and clean it every six months. Its not that hard once u done it.
Andy
Andy
That puts a different spin on things, I thought it was your daily! Do you use the K&N oil? You can get it in a spray, very easy to control vs. the 'drip'.
How is the Green Air Filter as compared to stock filter?
My car hesitated at red lights before and it was fixed by replacing the MAF. I did not know that the MAF should be cleaned every few months. Is the MAF easily accessed? Any instructions here? What do you use to clean them?
How is the Green Air Filter as compared to stock filter?there is a story behind the green filters too
My car hesitated at red lights before and it was fixed changing the MAF. I did not know that the MAF should be cleaned every few months. Is the MAF easily accessed? not for the first time Any instructions here? there is one laying around here..just have to search i dont remember where What do you use to clean them? CRC cleaner from autozone,pepboy everywhere
![](http://i230.photobucket.com/albums/ee160/tienxoxo/11-21-09_1345.jpg)
Andy
https://mbworld.org/forums/clk55-amg...or-online.html
not sure it will help but its all about cps and maf.
Andy
hey no offense at all Wes but let me try to find the thread about that. It was all about the green filter is melted in his airbox...you heard it right its melted. See if i can find it.
Andy
Andy
I have not had any issues with my K&N filters, but when I clean them I do not put much of any oil spray on the side that goes to the MAF. On the intake side I put enough oil though. So the rear is not very oiled but then I make sure to let it dry for atleast an hour before I reinstall them. So after 15k miles I still have no issues.
On the other hand I did have my CPS replaced this weekend since it made my car stall for no reason.... Thank you CPO warranty.
I have heard both things about K&N filters since they are heavily oiled from the factory. I was told by the shop foreman at the dealer that you should clean the filter and not apply as much oil even with a brand new filter to keep from having this problem. so I followed his advice and my car is running like a champ!
There was an initial problem with the rubber compound used for the edge seal/gasket with the Green filters but it's been rectified. I read about it quite a while back on a few different forums.
Andy
took off the MAF and sprayed with some MAF cleaner and the car is silky smooth now!!! no more hesitating...shifting is so much smoother
feels like a completely new car!!!
took me freakin 2 hours to get the MAF sensory loose tho
