"balance shaft" question
Old Nov 14, 2010 | 11:45 PM
bambu1's Avatar
clk350
Hi,
I stumbled across a thread on another website where owners of clk's were complaining of issues with cam balance shafts needing replacement. Consensus was that it affects various models with early "272" engines.
Question: Is it possible to determine if my car has an early 272 engine by deciphering the VIN code, and if it has a potentially defective balance shaft? (I own a 2007 clk350 coupe.)
Thank you.
Old Nov 15, 2010 | 12:37 AM
Kevwood's Avatar
'05 C200K SS, '05 Kleemann CLK500K, '08 Hummer H3 & '92 Z34 5sp (track car in Canada)
If there was a service issue raised by MB then yes, you can call/visit them with your VIN and have them check to see if you fall within the time period/production run. Good luck and hope you don't have any problems.
Old Nov 15, 2010 | 01:02 AM
Klinh's Avatar
C63s Cabriolet, BMW M4, Civic
Originally Posted by bambu1
Hi, I stumbled across a thread on another website where owners of clk's were complaining of issues with cam balance shafts needing replacement. Thank you.
Hmmm..........never heard of such issues. What do you mean by "cam balance shaft"? The cam are out of balance cause vibtation?
Old Nov 15, 2010 | 01:51 AM
Kevwood's Avatar
In a lot of OHC V6 engies a 'balancing shaft' is installed in roughly the same as where the cam shaft would be on an OHV engine. It's purpose is litterally to balanse out the rotating assembly and control vibrations. The one in my Z34 does the same as well as drive the oil pump, my 4.3L6cy Blazer also had one years ago.
Old Nov 15, 2010 | 02:17 AM
Klinh's Avatar
Let me ask the questions again. Which is bad.......the cams shaft (the cams itself) or the cams balancer (which has gears)?
Old Nov 15, 2010 | 05:44 AM
Kevwood's Avatar
He said balancing shaft in his original post.
Old Nov 15, 2010 | 01:47 PM
unitfreebie's Avatar
2006 CLK 350 Fog City, CA, USA
Hey Guys.. check out this thread on Benzworld, see post #7 for specific problem as the Balance Shaft Sprocket gear and engine serial number affected:
http://www.benzworld.org/forums/w209...-retarded.html
Please post back here what you find out and if the dealer will fix it for you under warranty or not?
Old Nov 16, 2010 | 08:28 PM
bambu1's Avatar
clk350
Hello all,
Thank you for the replies regarding the cam balance shaft issue.
1) I e-mailed the dealer's technician via the dealership website...(Nov 17, 2007 update: they called me to inform me that unfortunately, my car was built with the defective cam balancer shaft. They won't replace it until the specific error code displays...then they follow the Technical Service Bulletin (see below). I'm furious that Mercedes sold me a CPO car, knowing about the problem and not informing me BEFORE the purchase! Don't they call that consumer fraud?)
2) This is known problem for a variety of mercedes benz vehicles with the 3.5 Liter "272" / "273" engines built between 2005 and 2008, including our clk's!
3) Check out this website for threads and the TSB related to this issue [go to Thread #12]. Shows photos, diagrams, etc.... http://www.peachparts.com/shopforum/...d.php?t=271866
Here is the link to the Technical Service Bulletin (TSB): http://www.motor-talk.de/forum/aktio...hmentId=681441
thx.
