Oil Change
Old Nov 20, 2010 | 03:43 PM
mis3's Avatar
2004 CLK320
Oil Change
For my 2004 CLK320, I used to think that the only way to remove the oil was to suck the oil from the top.
A ex-MB technician told me that there is a "hidden" drain hole in the bottom. Is this true?
Old Nov 20, 2010 | 03:46 PM
dopeclk's Avatar
2004 CLK 320
im not sure about "hiddden" there is a plastic cover under the car that you take out the clips and slide it off and there is a drain plug. how exactly did you suck the oil out from the top?? just curious
Old Nov 20, 2010 | 04:10 PM
billyhead1's Avatar
CLK 320
Here's how it is done from the top.
http://www.autosportcatalog.com/inde...:referralID=NA
Old Nov 20, 2010 | 05:35 PM
ahmadk's Avatar
2011 E550 Sedan
it's not hidden... but u have to remove the plastic cover under the hood....
my mechanic does it to my car every time
Old Nov 20, 2010 | 06:55 PM
M-bENZ's Avatar
Corrolla
just buy the pump (around $70) and evacuate the oil from the top...clean , fast and easy.
Andy
Old Nov 20, 2010 | 08:11 PM
dynomite05's Avatar
04 CLK 320 > CLK32K
Andy
Do you use the pump?
Old Nov 20, 2010 | 11:07 PM
Kevwood's Avatar
'05 C200K SS, '05 Kleemann CLK500K, '08 Hummer H3 & '92 Z34 5sp (track car in Canada)
Andy
Gravity is cheaper
Old Nov 21, 2010 | 08:26 AM
mis3's Avatar
2004 CLK320
Originally Posted by Kevwood
Gravity is cheaper
I think that draining from the bottom is cleaner. Gravity will move all the oil out and quicker.
Old Nov 21, 2010 | 08:43 AM
Kevwood's Avatar
It's gotta remove more oil, no question. You can pull the plug and leave it for as long as you want. The pump is certainly clean and 'quick' but I'll stick with Sir Isaac Newton when it comes to oil changes.
Old Nov 21, 2010 | 09:25 AM
Yuille36's Avatar
Veteran: Marine Corps
07 E63 AMG, 10 C63 AMG, 07 E63 Designo, 07 E350, 09 C300, 07 C230
I have been changing my oil this way for years, I don't like sucking it out from the top. To me, it seems that you'll won't be able to get all the oil out this way. But if you drain it from the bottom, gravity is your friend. Just my two cents!
Old Nov 29, 2010 | 05:13 PM
Daca's Avatar
CLK 320
+1
Old Nov 29, 2010 | 05:42 PM
M-bENZ's Avatar
Corrolla
it is your choice....I have been used the pump for all the cars in my family.
Andy
Old Nov 30, 2010 | 10:28 PM
madmla21's Avatar
CLK 500 & E55 AMG
I use the pump actually used it last night on my mom's S350 every time I have used it I have pulled out the exact amount of oil I put in it. After you use this method I promise you will never go back to pulling the drain plug. You get out just as much along with any of the bad things in the oil.
Old Dec 1, 2010 | 01:59 PM
kostas86's Avatar
V8, Flat 6, V6, & Turbo flat 4
agreed
Old Dec 3, 2010 | 11:27 AM
Kevwood's Avatar
Do the MB service dealers in the US use the pump to evacuate the oil from the top? They don't here, they drain.
Old Dec 4, 2010 | 02:00 PM
2MCHCAR's Avatar
Supercharged CLK500,ML500,S580
I top drain my oil changes. The gravity method is probably better, but only marginally (but you have to do the extra steps just to get the the drain plug, and you have to buy a new drain plug ring because they can't be reused).
