powerchip question
Old Dec 27, 2010 | 01:35 PM
08clk350's Avatar
powerchip question
i am planning on getting the powerchip for my w209 clk350. is dyno tuning a must? thanks for your help!
Old Dec 27, 2010 | 01:50 PM
dynomite05's Avatar
04 CLK 320 > CLK32K
It's not a must, but it's a great way to see what you're paying for.
Old Dec 27, 2010 | 01:53 PM
08clk350's Avatar
thanks for your help dynomite...you always come through....
dynomite05's Avatar
04 CLK 320 > CLK32K
No prob.
Old Dec 27, 2010 | 02:00 PM
MarcusF's Avatar
2002 CLK430
Isn't that more of getting a baseline, and then having a look after the upgrade? No dynotuning is actually done, is it? Just dyno runs, right? Not trying to nitpick, just trying to understand what's being suggested.
buffyclk500's Avatar
clk500
if u r bone stock u will not c a big diff with a dyno tune
Old Dec 27, 2010 | 02:31 PM
08clk350's Avatar
in my case i am running 100% stock and getting the powerchip ecu. and yes...the correct term i should have used is dyno run....sorry...
Old Dec 27, 2010 | 02:36 PM
dynomite05's Avatar
04 CLK 320 > CLK32K
The first tune I did I was primarily stock so I didn't dyno. My second go around I would like to get a custom tune with dyno after installing the pulley kit, exhaust, airbox.
Old Dec 27, 2010 | 02:40 PM
08clk350's Avatar
did you see a difference from ecu upgrade? do you think its worth getting?
Old Dec 27, 2010 | 03:50 PM
dynomite05's Avatar
04 CLK 320 > CLK32K
I did see a difference, and for the money it's worth it IMO.
Old Dec 31, 2010 | 04:27 AM
Jhuey's Avatar
CLK
I have the powerchip tune and love it. Theres a lot of pluses and its really noticeable in pulling on higher rpms for me. Normally where it would shift in 3rd it gives an extra little pull. That made it all worth it right there.
Old Dec 31, 2010 | 07:50 AM
Kevwood's Avatar
'05 C200K SS, '05 Kleemann CLK500K, '08 Hummer H3 & '92 Z34 5sp (track car in Canada)
Yes, before and after dyno runs are just to see the actual gains and to make sure the A/F ratio is in check.
True dynotuning is a whole different story and is the best way to go. In the past I use to use 'out of the box' chips and flashes, 8HP here and 10HP there, nothing worth writing home about. Then I ended upgetting a contract to manage a speedshop/custom fabricator and a few performance stores for years, we brought in a Mustang dyno and did proper tunes, some would take a whole day (or more) but the results were quite impressive. The owner of the speedshop, and very good friend of mine, has made some moster power on that dyno.
I'm really happy that I found a shop here with a true dynotuning setup, I'm going to do baseline and after mod runs then top it off with a custom tune. I suggest it to everyone who has the money for it, it's the most thourough and safest was to go.
My $0.02
