Kevwood's mods - The Mountain of Goodies
So, when I get back I'll have to go down and get some pics myself. So much for recording this build step by step
Also got an email with a tracking number for the last big goodie for the car - it should be in Dubai in the next day or so
The vents are going to let a ton of supercharger heat bleed out, so it's functional. I ordered the full carbon fiber one so it's finished on the top and underside, it'll show off well when it's open. I also was going to paint it white but now that I have it and see the quality of the weave and finish, wow. The hood is flawless. We test fit it on the car and I must say, it make the car look very, very aggressive.
I'm going to leave it as is and drive the car for a while to see if I like it, if not, I can always go back and have it sprayed white.
Lol, lots and lots and lots of research and phone calls pal. I started calling manufaturers directly a while back instead of going through retailers, the options opened up from that point on.
Thanks dude.
You need to start ending your comments with "thank you, thank you, I'll be here all week. Please don't forget to tip your waitresses"Last edited by 2ng; Mar 12, 2012 at 08:18 AM.
I knew you'd like this one dude
Both of these scenarios result in greater cooling.
As for turning the vents around, if that were done in place you would be attempting to create a ram-air scenario in a low pressure zone, obviously this will not be effective. The vents would need to be moved far forward on the hood to the front area. Doing this would allow for air to be rammed in, but doing so would be counter productive as it would be forced against the heated under hood air and reduce the cooling effect. The only ram-air setup that would be effective is if it was plumbed into the air intake boxes and thus would have no negative effect on cooling.
As for painting the hood, maybe, maybe not. My original plan was to paint it but after seeing, how flawless it is and it on the car, I am going to leave it for now. I can always paint it later if I think the look is too aggressive for my tastes.
Thanks Mike
