Mikata's spring mods
Old Dec 5, 2011 | 12:34 PM
  #276
clk63DK's Avatar
CLK 63 amg
Back from Essen motorshow...
Lots of tunes cars, crap products and nice extras :-) Favorite: Brabus Bullit... or maybe one of the SL65's...
Anyway, back to business. Is your target to make a similar install?
If yes, then you need following parts:
Speakeradaptors for installation of front speaker
- Front. The ones you ordered.
- Front/rear. slaugther the OE speakers in your car
If you anyway want to go and get a set made in fiber board (never use any type of wood in the doors (unless sealed with paint or polyester) you should get a set done for the original also.
For connecting the x-overs to the car, you need: http://www.ebay.com/itm/ws/eBayISAPI...#ht_754wt_1037
The rest takes place after the xover.
For the rear woofer you need to do a bit more DYI and insert an inductor to cut the mid/high frekv. from the rear woofer.
This is to be put in series with the '+' on the speaker signal for the rear woofer.
http://www.parts-express.com/pe/show...number=255-812
This is the principle.
One thing you should invest time in, is to dampen the doors! Use a Dynamat door kit to silence the metal. It is well worth the time!
if you need more info let me know, but I'm without my own PC for a few days now, so pls be patient if I'm not online.
Chris
Old Dec 21, 2011 | 01:50 PM
  #277
mikata's Avatar
Mercedes CLK 320 W209
This came today.
One of many more parts to come in mikata's spring mods round two
Attached Thumbnails Mikata's spring mods-img_20111221_145041.jpg   Mikata's spring mods-img_20111221_144807.jpg
Old Dec 26, 2011 | 08:05 PM
  #278
grech's Avatar
Mercedes CLK280 2007
Chris
Chris! Thanks a lot for your helpful input man. Ah the Brabus Bullit...saw it at the IAA this year in Frankfurt...what a beauty. Although I may get flamed for saying this, I personally love AMGs way more than Brabus tuned Mercs...I just think some of the Bs get way too overdone in terms of styling. But then again, I've never driven one so I shouldnt be talking.
My plan is to keep the install a bit simpler. In the past few weeks, I've bought Polk Audio MM series component speakers for the front and the DB series coxial ones for the back pair. Today I received the Pioneer 4 ch amp (60W rms to each speaker) and I already received the Dynamat door speaker kit I ordered last week. Everything goes in the car tomorrow, along with fiberboard speaker rings that will be fabricated by the installer shop. Fingers crossed.
Old Dec 27, 2011 | 02:37 AM
  #279
mikata's Avatar
Looking forward to some pics!
Old Dec 27, 2011 | 02:59 AM
  #280
johnbill1236's Avatar
mbw
Haha är du dansk? You drive a 63?
The taxes on cars are crazy high in denmark, volvo s80 costs as much as a new BMW M5 E60 Or am I wrong?
Edit: Now I see you live in Malmö, I work in Malmö
Old Dec 27, 2011 | 04:10 AM
  #281
mikata's Avatar
Old Dec 27, 2011 | 08:24 AM
  #282
Glyn M Ruck's Avatar
Super Moderator
Originally Posted by mikata
This came today.
Going full Thermotronic are you?
Old Dec 27, 2011 | 08:45 AM
  #283
mikata's Avatar
Just a plug and play swap.
But out of curiosity, what do you mean with full Thermotronic?
Old Dec 27, 2011 | 09:21 AM
  #284
Super Moderator
Benz Aircon comes in two forms. Thermatic which is basically 2 zone manual & Thermotronic which is fully automatic climate control with a sun sensor so that the aircon blows colder on the side of the car that receives the most sunlight. Your controller above is for the full Thermotronic HVAC.
Old Dec 27, 2011 | 09:31 AM
  #285
mikata's Avatar
I've been doing some research on that and it's a lot of work to covert it to fully automatic. "It will cost more than it will taste".
Old Dec 27, 2011 | 03:07 PM
  #286
Super Moderator
Then just make it look pretty My C240 had the Thermatic & my CLK has the full Thermotronic. There is nothing wrong with the Thermatic. It works just fine!
Old Dec 27, 2011 | 04:24 PM
  #287
mikata's Avatar
Old Feb 16, 2012 | 06:54 AM
  #288
NsXTaCY168's Avatar
2009 CLK 550---2008 BMW 335i--2006 SLK 350----1996 Acura NSX ---- 2000 CLK convertible---1997 BMW M3
Hi Mike,
There is something basic wrong with the solution made.
The "right" pipe is wrong... You cant connect before the muffler unless you add a second muffler..
Normally you should have done your quad pipe setup as I tried to draw on my drawing here!
Would that diagram setup work with the stock AMG dual exhaust? Is there enough room to run a 3" pipe across to the right side?
Old Feb 17, 2012 | 03:37 PM
  #289
clk63DK's Avatar
CLK 63 amg
Yes - and if the 3" is too tight then run a 2,7 or 2,5 or get the 3" rolled to be flat.
Old Feb 18, 2012 | 12:08 AM
  #290
Kevwood's Avatar
'05 C200K SS, '05 Kleemann CLK500K, '08 Hummer H3 & '92 Z34 5sp (track car in Canada)
You just need to run a 2.5" over there, no need for a 3" as that is the inlet size, outlet should be dual 2.5". I also don't suggest flattening out pipe, it just cuts the flow down, Save yourself the labor and use a pipe that fits.
Old Aug 12, 2012 | 03:16 PM
  #291
mikata's Avatar
Time to dust of this thread a bit.
So I've had the digital luxury climate in storage for a while(almost 8 months), I haven't really had time to install it, but I had the chance to do it today.
Chris/clk63dk and I spent a few hours fiddeling with the car and planning my upcoming audio mods.
The install of the climate control only took 10 min btw.
When we both get a chance(hopefully in the beginning of next month) we will install dension gateway lite and Helix amp for my Helix speakers.
On my 40min drive home I noticed my air ducts only blowing hot air no matter what I had set on the climate control.
I knew I had to reset it, but since I was on the freeway, there was no chance of pulling over and reseting it so I turned the AC off.
So 40 sweaty minutes later I got home and reset it.
How to reset pre-face digital climate control:
A reset of the unit should be performed so the position of these flaps are reset and learnt. To reset the unit hold down the demist and recirculation buttons for > 5 seconds, if successful both LEDs flash and the unit will cycle the flap motors to normalise their posotion.
Reset should normally take 30sec or so but mine took way longer and I had no patience to wait so I shut the car of and turned it back on and go figures everything works as it should.
A before and after pic.
Attached Thumbnails Mikata's spring mods-img_20120812_152541.jpg   Mikata's spring mods-img_20120812_154128.jpg
Old Aug 16, 2012 | 03:51 AM
  #292
Kevwood's Avatar
Nice job once again Mikey.
Old Aug 16, 2012 | 10:16 AM
  #293
mikata's Avatar
Thanks Kev!
I will send you some pics once the Helix amp and dension gateway are installed
Old Sep 8, 2012 | 05:53 AM
  #294
clk63DK's Avatar
CLK 63 amg
Thanks Kev!
Next Saturday mate?
Old Jun 3, 2013 | 05:22 PM
  #295
mikata's Avatar
Feels like I haven't been on mbworld for ages.
Have kept myself busy with work and traveling this past year that I haven't had time to post on mbworld.
Trying to get back in the game again
I haven't really done much to the car more than installing Eibach springs(lowered by 30mm) and bi-xenon headlights last weekend. Few pics attached.
I have two more mods to do, after that I'm done modding it. I just want to enjoy it as it is.
Things left to do are:
*True dual exhaust
*6/4 pot brakes(whenever I find a good deal on the brakes).
I'm getting the C55/CLK55 spare wheel well for this setup.
Mufflers I'm getting:
http://www.ebay.de/itm/Fox-Sportausp...item19dd1235c4
Hopefully I'll have the exhaust setup done by the end of this year.
/Mike
Attached Thumbnails Mikata's spring mods-20130531_163446.jpg   Mikata's spring mods-20130531_225553.jpg   Mikata's spring mods-20130531_225632.jpg   Mikata's spring mods-20130531_225658.jpg
Old Jun 3, 2013 | 05:36 PM
  #296
Kevwood's Avatar
Looking good Mikey, every time you post up it's always a nice upgrade
Old Jun 3, 2013 | 05:58 PM
  #297
mikata's Avatar
Tank you for the kind words Kev.
Old Jun 4, 2013 | 04:17 AM
  #298
Kevwood's Avatar
Kev and kind are two words I don't often hear together
I'm going to be in London a few times again this summer pal, you up for another meet-up?
Old Jun 4, 2013 | 04:42 AM
  #299
mikata's Avatar
lol
Absolutely. My vacation weeks are 28-31. I'm in San Fran and San Diego week 28-29. Im back in Sweden after that. If those weeks doesnt fit your schedule, I still have more vacation days saved up PM me the dates you have in mind.
Old Jun 4, 2013 | 07:11 AM
  #300
AvocentAMG's Avatar
CLS550
Nice bumper
