Going to install DYI the camber kit today.
Old Mar 19, 2011 | 09:19 AM
Mka77's Avatar
06 CLK350 -SOLD! 2010 Cadillac SRX Premium Turbo
Ghostrider's Kit. Any final words of advice or wisdom?
Old Mar 19, 2011 | 09:21 AM
chrislis's Avatar
2005 CLK500
DIY. start there
Old Mar 19, 2011 | 09:25 AM
Mka77's Avatar
Going to install DIY the camber kit today.
Originally Posted by chrislis
DIY. start there
Still early. Thanks for the none essential wisdom.
Old Mar 19, 2011 | 10:00 AM
dynomite05's Avatar
04 CLK 320 > CLK32K
I wish I could help, but my shop did the install. I know the measurements have to be 12" from center hole to center hole.
Old Mar 19, 2011 | 11:30 AM
Mka77's Avatar
Thanks Wes. One side down. 1 1/2 hours including the learning curve. Some bolts are just a bit hard together at.
Old Mar 19, 2011 | 11:53 AM
Clkboi's Avatar
CLS550 4Matic
good news. pic pic pic
Old Mar 19, 2011 | 12:07 PM
dynomite05's Avatar
04 CLK 320 > CLK32K
The other side should be a breeze after doing it once.
Old Mar 19, 2011 | 01:39 PM
Mka77's Avatar
Finished up. After the first side it was pretty easy. Here was the catch with the install;
Where the oem camber strut attaches at the hub the torx bolt head can't be removed to remove the strut without taking the other strut bar attached just below it that attaches back to the frame toward the front of the car. I attached a half *** photo of it.
2 Jacks are needed. One to rise the car, and one under the hub assembly frame to then lower the car onto slowly.
Then its just a matter of raising or lowering the jack under the hub to get things lined back up. It takes a little pushing and pulling.
Some of the bolts are a little tough to get at. Wrenches are the only tools that will get where you need to get.
The car now appears to be sitting very nicely with maybe a bit of positive camber that I'm sure will settle after driving a bit.
It was about to rain so I will post up pictures from the rear and post.
Attached Thumbnails Going to install DYI the camber kit today.-image.jpg   Going to install DYI the camber kit today.-image1.jpg
Old Mar 19, 2011 | 02:00 PM
dynomite05's Avatar
04 CLK 320 > CLK32K
Congrats on the install.
Old Mar 19, 2011 | 02:10 PM
Mka77's Avatar
Thanks, Wes.
Next up is to have the alignment checked at the shop Ghostrider uses. I'm going to take his advice and have it done with the stock wheels on.
Just need to get my new rear tires mounted and hopefully put everything on next weekend.
Old Mar 19, 2011 | 03:14 PM
Mka77's Avatar
Here's a DIY thread for the install. One thing I didn't try was prying the inner mount to let the oem camber arm drop down Item #9. This step may eliminate the bottom strut arm being removed.
https://mbworld.org/forums/c-class-w...amber-kit.html
Old Mar 20, 2011 | 07:46 AM
elijah's Avatar
Euro Cars Only
Good stuff!
Old Mar 20, 2011 | 12:18 PM
Kevwood's Avatar
'05 C200K SS, '05 Kleemann CLK500K, '08 Hummer H3 & '92 Z34 5sp (track car in Canada)
Nicely done Mike. I just received my kit today, hopefully I'll have it installed in 2 weeks.
Old Mar 20, 2011 | 02:06 PM
Mka77's Avatar
Thanks Kev. Wasn't that bad of a DIY. Just took it out this morning for a drive just to check for any strange noises, creaks or squeaks. None to report. Drives like it should. Cheers
Old Mar 20, 2011 | 03:44 PM
dynomite05's Avatar
04 CLK 320 > CLK32K
So you finally got it from customs, huh.
Old Mar 21, 2011 | 12:22 AM
Kevwood's Avatar
Always good when everything goes to plan mate.
Ya, what a nightmare eh? First USPS sucks and they have no idea what happens to their shipments after they leave the US (long story), then because they have no Mid East representation the packages get dumped at customs with no tracking numbers...
Anyways, yes, after months and months - I got it. This car is going to age me 10 years in the 1 year it takes to get it finished!
Old Mar 21, 2011 | 07:58 PM
Mka77's Avatar
Working through the "to do" list. Going to check this off tomorrow.
