Racing CLKs with automatic transmission
I've tried both in my 05 CLK against a 335i and I think shifting manually seems a bit faster. Out of 3 races I won 2, once just using sport driving, and once shifting with the paddle shifters. However, I also lost once using the paddle shifters, which may have been a result of bad shifting on my part.
What do you guys think? Also, ESP on or off? I had a bad experience with it off and i'm almost thinking it would harm more than help. Thanks
As far as any type of "racing" with twisties and turns and elevation changes, manual mode is definitely the way to go.
I turn ESP off if it's like a drag type deal, since you don't want your tires to catch some sand off the line and bog down, but I always turn it back on right after that, considering ESP can be a lifesaver.
Road Racing: Keep it in automatic lol. Ive tracked both a 500 with the 5 speed, and a 550 with the 7 speed, and I keep both in automatic. On the road, I think you do need the paddle shifting to get the most out of it. But once on the track, you'll do great with it in automatic! In fact, once on the track, the transmission really loves to hold gears!!!! Its so different from when its on the road, and you have to follow speed limits. Haha. On the track, under lots of aggressive throttle, it seems to be right at home. In fact, on my cool down lap, the transmission is still usually stuck in its racing mindset, and it still holds the gears during the cool down lap. Its almost like its asking to stay out longer
Esp: Drag racing you can turn it off. For road racing, I'd say use your discretion. The first few times on road tracks, I kept it on. There was only one sweeping corner that I pushed it hard enuf that the traction control would kick in (you can even hear it in videos cutting throttle haha). Once you learn the course, if you find the traction control is cutting in, I'd say turn it off. It will at least keep the throttle cut-off from going off a lot. Its really something you should choose at your own discretion. Again, I'd start with it on, see how often you set it off (and why you set it off!!!!) and decide from there. If you set it off because you are pushing g's, turn it off. If you are setting off t/c because you aren't smooth on track yet, keep it on!
In all honesty, I like having the automatic on track. When you are new to racing, you tend to downshift at the wrong times which upsets the balance of the car. I've seen more than a few off tracks happen that way. With the automatic, its one less thing to have to divide your attention to, and makes it so you can concentrate on other things.
If I was to give two suggestions for road racing upgrades (they are great road upgrades too), get yourself some H&R sway bars, and EBC Yellowstuff brake pads (or whatever your brand preference, but road/track pads). I've raced on the Redstuff pads, and our cars are just to heavy for them to last full 20 minute sessions at full pace. Go to fcpeuro and get the yellowstuff pads, which will also come with a lifetime replacement. https://www.fcpeuro.com/page/lifetime-guarantee
In case you want to see some clk track action haha.
