***Official Wheel/tire/stance Fitment Thread***
Subscribe
Sep 30, 2013 | 02:32 PM
  #776
Quote: So i was searchibg my local CL when i stumpled upon 19 chrome madrus manhilliem wheels at a pretty decent price. I would like to know if there is anyway i could get these to fit. If so, how?
Heres the specs he gave me...
5x112
Rear 19 x 10 1/2 backspacing 7 3/8" 35mm offset
Front 19 x 9 1/2 34mm offset backspacing 6 1/2
Thanks for the help!
from what i can tell the back might be a tight squeeze, but i don't think the front will fit.
Im hoping someone with more knowledge with 19x9 and 10x10.5 can help. if you can fit it that would be great because that will open up a larger used selection for us =]
GL
Reply 0
Oct 1, 2013 | 09:40 AM
  #777
10.5 is wide. you'll have a high chance of hitting the inner fender liner or strut.
you may have to run a 5mm or 10mm spacer and run stretch your tires.
Reply 0
Oct 1, 2013 | 12:14 PM
  #778
I wouldn't mind doing both as long as I don't have any issues...
what's your opinion on the 9.5 up front? I just don't know how I would go about making sure they would fit and what sizes tires I would need to buy.
Also, considering I'm not dropped how do you guys think it will look?
Reply 0
Oct 1, 2013 | 01:38 PM
  #779
Quote: 18” AMG split spoke rims from 2006 CLS
18x8.5 ET+25
18x9.5 ET+28
Hankook Ventus V12
225/40-ZR 18
255/35-ZR 18
No spacers, no mods. Different bolts were needed. Offsets pushed them out nicely!
Would a 24mm shank be ok with this setup? Thanks!
Reply 0
Oct 7, 2013 | 07:32 PM
  #780
I'd be shocked if 9.5's would fit up front.
On my 06 CLK350, which I just bought used, whoever did wheel/tire work on it before put 235/45's all around and, based on the fact that the bead of the larger tire (225 -> 235) in what should be the smaller (7.5" rim) looks stretched and the bead of the smaller tire (245 -> 235) in the larger (8.5" rim) looks pinched, I can only deduce that they also put the rear rims on the front and visa versa...
All that being said, with the 8.5's being upfront, there isn't enough room for my pinkie finger between the rim and the gas strut. You could space it but I would hate for my fenders to be ruined from scraping the tire.
Consequently, does anyone know if there is any kind of rim size labeling I could look at to confirm my theory without having to remove the tire from the rim and measuring?? That would be SUPER HELPFUL!
Reply 0
Oct 8, 2013 | 11:28 PM
  #781
w209 clk500 (stock height) on oem w219 wheels.
- 18x8.5 et25 | 235/40-18
- 18x9.5 et28 | 265/35-18
- 12x1.5mm lugbolts | R14 ballseat | 26mm shank
***Official Wheel/tire/stance Fitment Thread***-dsc_9965_zps2c662421.jpg
***Official Wheel/tire/stance Fitment Thread***-dsc_9982_zps9d76b175.jpg
Reply 0
Oct 12, 2013 | 03:39 PM
  #782
Very nice!
Reply 0
Oct 13, 2013 | 01:30 AM
  #783
19x9.5+20
225/35/19
***Official Wheel/tire/stance Fitment Thread***-img_20130823_195920_zps69dba259.jpg
***Official Wheel/tire/stance Fitment Thread***-forumrunner_20131012_222929.png
Reply 0
Explore
Oct 13, 2013 | 10:58 AM
  #784
eddiero, sweet jones; very VERY nice rims!
Reply 0
Oct 20, 2013 | 03:52 PM
  #785
new wheels and tires
18x8 32et and 18x9 35et Roderick rw2. Michelin Pilot sport as3 tires. 225/40r18 front and 255/35r18 rear
***Official Wheel/tire/stance Fitment Thread***-20131020_153437.jpg
Reply 0
Oct 20, 2013 | 07:06 PM
  #786
RH AN would fit....
Hi mates!!
I have bought RH AN:
Front 9x19" ET49 in 235/35/19
Rear 10,5x19" ET43 in 275/30/19
Please give me spacers options not to rubbing but in the limit inside with the struts so having thes less as possible outside.
I'm thinking about +20mm front and rear.. but maybe 19mm is better, please help me!
Could fit?
CLK w209 320cdi
***Official Wheel/tire/stance Fitment Thread***-img-20130902-wa0013.jpg   ***Official Wheel/tire/stance Fitment Thread***-img-20130902-wa0014.jpg   ***Official Wheel/tire/stance Fitment Thread***-img-20130902-wa0010.jpg   ***Official Wheel/tire/stance Fitment Thread***-img-20130902-wa0012.jpg
Reply 0
Oct 28, 2013 | 09:54 PM
  #787
MY first Benz clk 500 amg '03
more pics about to come......did plasti dip tail lights very easy and cheap......has 19' rims bought it like that looking to get silver rims.....and paid $80 for tinting the windos got 35% all around....what you guys think?
Reply 0
Oct 28, 2013 | 10:01 PM
  #788
Quote: 19x9.5+20
225/35/19
wow thats a low drop. I had to raise my fronts by .5 inch (Bilstein PPS9) as I ran in to trouble. Hit a pothole while turning and the wheel hit the bottom of the fender banding it out a bit. Lucky its not so bad and I banded it in by hand, mostly. Tire was fine as well.
Reply 0
Nov 13, 2013 | 11:31 PM
  #789
Hi Guys,
Just found a set of winter tires (245/45/17) & wheels (17x8.0 et32). Would this fit the 07 CLK550 coupe?
Thanks!
Reply 0
Nov 25, 2013 | 09:01 PM
  #790
hello... does anyone have a pic of our cars w/ da ROHANA RC10 on them.....n if so can u post it... Thanks
Reply 0
Nov 28, 2013 | 02:54 PM
  #791
I have just fitted
F:19x8.5 et 35 245/35/19
R:19x9.5 et38 275/30/19
what is the ideal spacer to order to have a more flush look, the front looks ok but the rear really needs it, would 15mm be sufficient? or go 20mm? currently on standard clk55 amg suspension but will be dropping it with H&R springs
any help would be great
Reply 0
Dec 5, 2013 | 07:25 PM
  #792
Anyone run a 10.5 wheel in the back? I will be stretching the tire a tad bit.. with a 265 30 19 on a 10.5
with offset of 37+..
Reply 0
Dec 5, 2013 | 08:30 PM
  #793
I did
Quote: Anyone run a 10.5 wheel in the back? I will be stretching the tire a tad bit.. with a 265 30 19 on a 10.5
I did run 10s on ET32 with a 10mm spacer for ET22. It was a stretch that I was not real comfortable with. But looked sick! So, 10.5 would be really stretched.
Reply 0
Dec 20, 2013 | 01:34 AM
  #794
Hi All,
I have just been able to pick up a set of 19" Brabus Monoblock VI's. These are 8.5x19 ET30 and 9.5x19 ET30.
We have no option for spacers as they are illegal here except for on Porsches.
Will these be a suitable fit for my CLK350 with 30mm lowered Eibach springs?
Tom
Reply 0
Jan 1, 2014 | 06:15 PM
  #795
Looking to get some new wheels and just want to double check that they'll fit fine with everything.
http://www.oewheelsllc.com/Wheels_3/...2#.UsSgwLR0koV
These are the wheels in particular. Anybody have experience with this company? I'm hoping they're not pieces of **** that are gonna break or bend.
The thing is, I'm hoping to take the tires off my current wheels and put them on these since they're reasonably new and I'd hate to throw them out. I know the back tires will fit, as they're 255/40/18. But I'm a bit concerned with the fronts. They're 225/40/18. I've looked it up and it seems like they'd fit, but it'll just look a little funny. Nothing too awful I hope? I don't want to be cringing every time I come out to my car.
If it matters, the tires are Sumitomo HTR Z III rears and Sumitomo Pro Tour LSW fronts. Any help in the matter would be great.
Reply 0
Jan 9, 2014 | 08:35 PM
  #796
Hi, I have 10mm and 12mm H&R spacers I need to let go if anyone is interested.
https://mbworld.org/forums/wheels-tires/526886-h-r-10mm-wheel-spacers.html
https://mbworld.org/forums/wheels-tires/526887-h-r-12mm-wheel-spacers.html
Reply 0
Jan 14, 2014 | 02:55 AM
  #797
w209 CLK55 Fitment
w209 CLK55 Stock Height (Needs Drop ASAP !!)
Wheels: MRR GF6
Size: 19x8.5 225 35 19 ET25
19x9.5 265 30 19 ET25
Tires: Nitto N555
I wanted to be as flush as possible without rubbing. The fronts should be good.
(With Camber from lowering Id imagine the Rears will need 10mm to be "Flush")
So if you want to be flush and play it safe, Id say 25 et in the front and 20 et in the rear.
Will post pics once its lowered on coil overs.
***Official Wheel/tire/stance Fitment Thread***-1.jpg   ***Official Wheel/tire/stance Fitment Thread***-2.jpg   ***Official Wheel/tire/stance Fitment Thread***-5.jpg   ***Official Wheel/tire/stance Fitment Thread***-6.jpg   ***Official Wheel/tire/stance Fitment Thread***-3.jpg
***Official Wheel/tire/stance Fitment Thread***-4.jpg
Reply 0
Jan 17, 2014 | 12:00 PM
  #798
guys what you think of these? http://www.car.gr/parts/view/4401534/
would it look ok? i have clk v6 w209 facelift front and plan to drop it and add a lip to front bumper.
Reply 0
Jan 17, 2014 | 12:01 PM
  #799
sexy clk with this et you went i suppose you wont need spacers for any reason right?
Quote: w209 CLK55 Stock Height (Needs Drop ASAP !!)
Wheels: MRR GF6
Tires: Nitto N555
Reply 0
Jan 17, 2014 | 01:05 PM
  #800
Thanks!! I didnt have to use spacers, however the rears I will probably add a 10mm to make it sit more flush once its dropped
Reply 0
