W209 (aftermarket) bi-xenon lights coming soon....
Old Sep 24, 2011 | 04:50 PM
  #376
leejak's Avatar
2007 CLK 350 Coupe, 2011 E92 M3, 2005 E46 330Ci Stick
Originally Posted by chrono12
Correct me if I'm wrong, anyone, but I believe the running lights are pole dependent. In otherwords if they aren't working, unplug them, flip them around and the bulb should light up.
Do you mean the 4 pin connector?....please advise....
Old Sep 24, 2011 | 05:12 PM
  #377
NsXTaCY168's Avatar
2009 CLK 550---2008 BMW 335i--2006 SLK 350----1996 Acura NSX ---- 2000 CLK convertible---1997 BMW M3
Originally Posted by marandod
can you try a direct wire?
Do not direct wire it as it would most likely void the warranty.
Old Sep 24, 2011 | 05:14 PM
  #378
NsXTaCY168's Avatar
Originally Posted by leejak
Hi:
I need to contact seller.....do you have his email address...thanks....
lee@speedstersource.com
The company's name, address, and phone number is also on the shipping label on the top of the main cardboard box.
Old Sep 24, 2011 | 05:16 PM
  #379
NsXTaCY168's Avatar
Originally Posted by ZEEK
Thanks Louie Hey everyone be careful when connecting the car's connector to the headlights connector. Those pins are not that great. Had a very tough time with them. But finally they are on and working. Btw I have a feeling those hids are not that bright.
Good to hear. Do you have the 6K or 8K HID bulbs? I have 6K and they are bright at night, way brighter than my OEM halogens. Wait till night time and take your car out for a drive.
Old Sep 24, 2011 | 05:19 PM
  #380
NsXTaCY168's Avatar
HI:
Of those who have these installed, does turning on daytime running lights result in an error code?.....I get a code that both right and left low beams are out......Help...Do these lights not provide daytime running lights option?..
Just curious, why would you want to have the headlights on during the day? I don't have daytime running lights on my car. My headlights turn on during the day if I manually turn it on.
Old Sep 24, 2011 | 05:21 PM
  #381
Louie D's Avatar
2015 E400 CAB, 2010 Jeep Compass, 2009 E350 Sedan
The reason why some people are not having all the lights come on is the MALE PIN CONNECTOR are pushing in and NOT making the connection to the Female connector some pins may go in some may not each pin = one Bulb so some lights may work some may not , Also another cause it you must make sure the are squeezed together all the way..
Old Sep 24, 2011 | 05:24 PM
  #382
NsXTaCY168's Avatar
For those that haven't installed yet, I highly recommend having them professionally installed, not a job for amateurs trying to save a few bucks. I mentioned that a long time ago before the seller started taking orders. If you don't know what you are doing, you may install them wrong.
I had a bodyshop that specializes in Mercedes help me install them. If anyone in the SF Bay Area want to use them, let me know.
Old Sep 24, 2011 | 06:26 PM
  #383
ZEEK's Avatar
Yo Momma
I have the 6k bulbs. I think the second projector (non hid one) that's only for high beam. And the small bulb right above it is the running light. Correct?
Old Sep 24, 2011 | 07:50 PM
  #384
leejak's Avatar
OK, great....I sent them an email...have not gotten a response as yet....but thanks.....
Old Sep 24, 2011 | 09:32 PM
  #385
NsXTaCY168's Avatar
They are closed on the weekends.
Old Sep 24, 2011 | 09:37 PM
  #386
NsXTaCY168's Avatar
No, running lights activates even during daylight. The small bulb above the high beam projector is the city/parking light. I ordered a LED 194 wedge bulb to match my low beam xenons. $19 through mike @ aznoptics.
Old Sep 24, 2011 | 11:54 PM
  #387
Louie D's Avatar
Ballast Pic's
1st pic is driver side 2nd is passenger side . SinceI was all greasy wife and I installed our camber kit today also, that was fun ha ha.
Attached Thumbnails W209 (aftermarket) bi-xenon lights coming soon....-100_3862.jpg   W209 (aftermarket) bi-xenon lights coming soon....-100_3863.jpg   W209 (aftermarket) bi-xenon lights coming soon....-100_3864.jpg
Old Sep 25, 2011 | 01:14 AM
  #388
ZEEK's Avatar
Yo Momma
Alright guys one more problem. My left headlight. This is the one I had a really hard time connecting to car's connector. The other problem is that when I first turn on the headlights, this left bulb flickers for a few secs then stays on. And the other problem with it is that its pointing way too high and when I try to adjust it to point it down, its not moving at all. I am able to adjust the right headlight with no problems. Should I contact the seller? What you guys think?
Old Sep 25, 2011 | 01:15 AM
  #389
ZEEK's Avatar
Yo Momma
So you mean to say that that high beam projector is always on with your headlights? If that's the case then why aren't mine on?
Old Sep 25, 2011 | 01:35 AM
  #390
NsXTaCY168's Avatar
No. The city lights come on if your headlights come on, not the high beams.
Old Sep 25, 2011 | 07:47 AM
  #391
RunInColorado's Avatar
2007 CLK350 Sport, 2006 E320 CDI, 1978 Cessna 152
Can you explain how to fix it? I noticed after reading your post that the male pin connector is a bit movable, and the female connector is not going all the way in. (checked the OEM as well as the other side). One side works beautifully for me, the drivers side will not light up at all. I put the old light in and it works well. Everyone else with problems may want to check to see if the connectors are coming together fully.
Also, has anyone had difficulty with the screws not fastening down? Like the MB screws are a size too small?
Old Sep 25, 2011 | 10:42 AM
  #392
Louie D's Avatar
The problem was on the drivers side on mine too.
The male plug on mine had connectors that pushed down when I connected the two plugs. I used needle nose pliers to pull the male connectors back into place. While doing so, I noticed the tiny clips/tabs on the silver connectors were smashed (or not as they should be to hold the metal in place).
Using a small screwdriver, I bent the tiny clips/tabs attached to the prong silver connectors out so that they would cause the connector to stay in place (or at least not push down back into the grey plug).
HTH
Old Sep 25, 2011 | 10:57 AM
  #393
HTH
Just went outside to see if I had similar problem. My easy solution, open the headlight housing where the bulb is, move the wires around until they line up, the male and female connector slide right on and SUCCESS! both sides light up! Thanks for the suggestions!
Old Sep 25, 2011 | 01:55 PM
  #394
ZEEK's Avatar
Yo Momma
Does anybidy have problems adjusting the drivers side headlight? It's pointing way too high and lighting up trees.
Old Sep 25, 2011 | 01:58 PM
  #395
leejak's Avatar
Aiming is pretty easy....need a 13mm socket.....turn the black nut(the inner of the two you can see on the top) and it will adjust the height of the beam....not sure what the other black nut adjusts....
Old Sep 25, 2011 | 02:18 PM
  #396
ZEEK's Avatar
Yo Momma
The other does left/right adjustment. I have tried with a screw driver in it. You used a rachet?
Old Sep 25, 2011 | 02:23 PM
  #397
leejak's Avatar
Yeah, the black plastic nut is 13mm so I just used a socket with a ratchet....the other nut does not seem to do very much.....I'm not noticing much left to right movement of the beam...
When I first installed these, they were pointed way down...and pretty much centered...
Old Sep 25, 2011 | 06:21 PM
  #398
Flame3g's Avatar
CLK500 SPORT
man what a day finished mine as well...they look amazing had to reseal the hole where the HIDs came in but no big deal...i must say it was kind of hard to plug the lights up but just take your time and they will come out nice..will post pics aswell
Old Sep 26, 2011 | 12:52 AM
  #399
Flame3g's Avatar
CLK500 SPORT
update went to adjust my lights and the driver side one started out fine then wont let me adjust up/down or left/right...really don't wanna remove this light only because it was a pain to put in...
Old Sep 26, 2011 | 01:59 AM
  #400
ZEEK's Avatar
Yo Momma
Same thing with me man. I'm about to contact seller and request a new piece. It's frustrating.
