W209 steering feel
Does anyone know if there is a way to tighten up the CLK's steering so it's not as light? Switching to Sport mode only does but so much...
When i installed a PSS9 there was a huge difference in steering wheel feel (heavier i could say) and now that i am back on a more soft setup steering wheel is much softer but nowhere near the stock setup ( i had the sports package)
Maybe you could try with some stiffer springs by the time the steering is hydraulic in our cars!
Recently i retroffited the parametric steering but i do not recommend going through these expenses even though you will notice a huge difference!
Russian MBZ Club VIN Decoder
Put your VIN in the field, press the button, and then on the next page, choose "Data Card" on the far right top of the page.
My CLK550 has parameter steering and it does feel very light at low speeds, but it does firm up well at highway speeds. It's also supposed to vary the feel depending upon how quickly and tightly you turn the wheel, hence the "parameter" nomenclature as opposed to "variable assist". My kid's C240 doesn't have it and the steering is very heavy. We swapped cars last week when I went out of town (no sense parking the CLK550 at the airport when she can enjoy it) and I found the heavy steering on the C to be "annoying".
İs there something wrong with my steering wheel?
Remember that tyres, tyre width & pressures all play a role.
As Rudeney said i tested it and i can turn it with finger even its a little bit firm. There is no problem with it i guess
I had changed the steering fluid during the summer with the MB-spec Pentosin CHF 11 along with full replacement of all suspension parts in the front (control arms, ball joints, shock absorber links, etc..)
My VIN is WDB2093651F136567 and I couldn't find "parameter" nor "variable assist" in the data card.
Can someone please chime on this matter? Is the steering a bit heavier because I don't have the parameter option? If not, where should I start looking.
The heavier feeling has been like that since I bought the car 1.5 years ago with 100,000 km on it and it now has 134,000 km.
http://benzbits.com/WDB2093651F136567.pdf
And yes, "parameter steering" is code 213 (which yours does not have).
I have W209 CLK 270 CDI. And the steering of my car is permanently heavy. I can`t turn it with one finger. Where its better to start to look.
How to check fluid level in steering system?
Thank you in advance!
