Brake Sensors and aftermarket pads?
Old Jan 6, 2012 | 01:10 PM
Mka77's Avatar
06 CLK350 -SOLD! 2010 Cadillac SRX Premium Turbo
Question for the group.
Got a great deal on some R1 Concepts rotors during a holiday special they had running.
I am going to install new Akebono's pads again, but remember something about the pads not having a hole pre-drilled in them. (My Indy did the install and made mention of). Any big deal here?
What particular brand, and where did you get yours from? The sensors that is.
A friend and myself are going to do the job here shortly and just want to make sure we have everything we need with no hiccups.
Thanks in advance, Mike
Old Jan 6, 2012 | 01:14 PM
Kevwood's Avatar
'05 C200K SS, '05 Kleemann CLK500K, '08 Hummer H3 & '92 Z34 5sp (track car in Canada)
It's easy to bypass the sensors, just clip the pad end off, twist the ends together and tape/heat shrink/loom it up - no pad error. I did this when I did my Brembo BBK conversion.
My Akebono pads did have the provisions though...
Old Jan 6, 2012 | 01:36 PM
Mka77's Avatar
Good info Kev. So the pads sensors can actually be by-passed with no errors that easily? Good to know. Thanks
Old Jan 6, 2012 | 09:32 PM
sleepyheadzzz's Avatar
2000 Volvo S40, 2006 Hummer H3, 2008 CLK550
i thought akebono had a brake pad model that was compatible with our sensors
Old Jan 6, 2012 | 11:49 PM
Kevwood's Avatar
Yep, it's simple. It was driving me nuts seeing the 'brake pad wear' indication every time I started the car, when I went back in for the follow up/check over I had them plug the bypassed sensors in and it works like a charm.
Old Jan 9, 2012 | 12:30 AM
M-bENZ's Avatar
Corrolla
huh ? any pics kev ? LOL
Old Jan 9, 2012 | 12:46 AM
Kevwood's Avatar
Could have got you one yesterday when I was swapping wheels...
It's easy, clip the end that plugs into the brake pad off, strip the coating off the ends of the wires (about 1/2 inch), twist tem together and put some heat shrink over it. Remember there are 2 of them (not 4), front and rear.
That's it, that's all
Old Jan 9, 2012 | 10:51 PM
M-bENZ's Avatar
Corrolla
got it.
Thanks.
