Bad vib around 50-55mph
2004 CLK 320, 07 Yukon SLT, 05 R6raven
Notice when I get up that speed I can hear and feel a bad vib. Can't tell if it's coming from the Yokohoma tires or front end ? Drive shaft ? Bad alignment ? Guess I can get the wheels rebalanced first. Has to be the tires right ?
1 Post
06 CLK350 -SOLD! 2010 Cadillac SRX Premium Turbo
Re-balance is always a good starting point. Could have throw a weight. It does take much to create a vibe.
Just a process of elimination. Let us know.
Sold 2003 CLK 500,2003 SL 500,2006 Acura MDX,1998 BMW M3 convertible
[QUOTE=JDenhamCLK320;5025439]I see. Coming to think about it the other day I ran over a pretty bumpy road and ever since then I notice the vib appear.[/QUOTe
Pray you didn't bent a rim or something !
Tacking on to the reply from jbenz99, I bent a rim and had the same vibration problem around 60 mph. Had the wheels rebalanced. It took the tech quite awhile to get it balanced. It was not until a couple months later that I noticed that I was losing air from one tire; not enough to set of a warning from the TPM system, 3-5 lbs over as many days, then much less.
![Tear](https://mbworld.org/forums/images/smilies/tear.gif)
I don't know specifically when I bent them, but think it was a pot hole while slowing from 55. I've hit a few pot holes over the 4.5 years I've had the car, but never had a bent wheel before. I run 18" wheels with original tire size.
It also depends on your tire pressure ..If one or all of your tires have low tire pressure and you drive over a bumping roads or just ran over a pot hole, it can bent a rim/s ! Also its still possible your wheels with proper tire pressure can hit a big pot hole driving around 20 and bent rim/s ! I highly recommend that if you are going to balance tires please have them perform road force balance !! That way it can check rims/tire's run out and also check for bent rim/s ..Good luck !!
