Oil Change, from Top or from Bottom
I am curious. I understand that for w209, there is a drain hole in the bottom. Isn't it beneficial to let the old oil to fall out by gravity? This way, all the accumulated sludge and deposits will be drained out as well.
Since my car is always serviced at the dealership, I do not have to handle the used oil.
I found an indie recently and he prefers to drain the oil from the bottom. I may give it a try with the ATF partial flushes.
If you want to reuse the old one you can seal it with a suitable Loctite or similar product.
With cars on Mobilodrive Maintenance plan Benz just throw them away.
Do you replace the drain plug? How much are these plugs?
Maybe you're supposed to change drain plugs, but I'm old school. I only change drain plugs when the threads get messed up which mine were not. From what I could gather from the million ft-lbs of torque that mine were tightened to I don't think that the dealer ever drained the oil from the bottom.
I ran the car. I stopped the car for 10-20 minutes and let the oil to get drained down to the pan.
The Check Oil Level in the display said OK. However, I went to dyno mode and at startup, the oil level said 7.0L. I recall that it used to say 7.9L at startup. Not sure how accurate is this oil level in dyno mode.
Should I put more oil? I was there at the oil change and he did put in 7.5L !
I just checked the owner manual. For my car, the oil capacity is 8 L.
