W209 headlight upgrade options for those with OEM Halogen; who's done what?
03-09 Mercedes Benz W209 CLK Class Chrome Quad Projector Xenon HID Headlight
Another option I've seen is this dual projector, which I'm told is SLR-like (I defer to you more detail oriented members):
W209 CLK 2003-2009 Chrome Dual Projector Headlight
That one says "Integrate with headlight auto leveling system" which I'm not sure of the meaning of (does it auto-level or not?)
There's already a thread about "halo lights," but most (including me) prefer a more OEM look:
03-09 Mercedes Benz W209 CLK-Class Halo LED Projector Head Lights Lamp
Of course, there's always OEM for just a little more than triple the price:
W209 03-06 Headlights Pair Xenon
What's the best solution for someone who wants a relatively OEM look (and function)? Are there other options I should consider?
I have those projector lights on my car and I think it looks better than OEM xenons.
https://mbworld.org/forums/clk-class...ming-soon.html
I know there are members who installed the lights themselves, but I highly recommend paying a shop to do it, less headache.
First OEM halogen were pretty good in light output with HID bulbs just not aggressive enough for the CLK IMO
I purchased OEM bixenon and loved them. I f**** them up trying to sand them down and am forced to sell them now.
OEM quality is awesome. Heavy headlights thick plastic and all that. Problem is that if your ballast or ignitor go bad you are screwed. Mercedes made them so you need to open the headlight to change any of these.
I just received my aftermarket quad headlights today. They look great and the quality is great as well. DEPO brand has a long story with aftermarket Mercedes parts and lots of people are happy with them.
What to get is a tough call really. if you can afford to buy and maintain OEM bixenon go for it.
The quad headlights are much cheaper and have a more aggressive look IMO (SLR style)
Depending on the light output quality which i will find out tomorrow i will re-edit this and let you guys know what was better in my experience.
I think I've already been made to understand that projector lights on the W209---whether OEM or aftermarket--- are not going to self-level when turned on, as my E350 does. That's too bad, as it's a cool element of those lights....
Still annoying for the car in front of you if you are on a hill or bumpy road but yah
The real issue here is beam pattern. Most halogen headlights allow the light pattern to extend upward where HID has a more sharp cut-off. This is because HID is brighter and the cut-off is to reduce the light projected into the eyes of other drivers. Any headlight type - projector, reflector or diffuser - can create a good cut-off pattern for HID light. The problem is the reflector lights in the W209 do not. They are designed to allow some light to extend upward to aid in illuminated signs, and thus if you put HID bulbs in there, it will annoy other drivers. Most projector headlights use the same beam pattern with a cut-off for both halogen and HID. They do this because (1) it makes it less expensive to manufacture only one lens, and (2) because projectors concentrate the light more, so even with halogen bulbs, a cut-off is appreciated by other drivers.
So, you probably shouldn't put HID bulbs in your CLK's reflector halogen light assemblies. If you buy Fishcake's reflector headlights, you can do either HID or halogen and it won't be a problem for other drivers as the cut-off should be OK. Finally, you should use a "white" bulb. While some people like a more blue or even violet color, it does not illuminate as well in terms of what your eye can see.
why are these only for halogen replacment ? how can i make this work with xenon. i believe my car came with xenon headlights . i have the same ones as the pictures posted above
I have found this option on Amazon. It has the LED DRLs and a HID Xenon upgrade
It says the bulb is 35watts, probably the same as my current Xenons. Perhaps the LED need the 55 watts?
These seem awfully complicated.
Thanks,
Michael
thanks for all the info rudeney, but when i look at the pictures from behind i do see a small box on the left , would that be the resistor that needs to be changed ?
