MB CLK200K 2007 with audio 20
Old May 28, 2012 | 02:05 PM
LAKIS1961's Avatar
2007 clk200
Hi everybody
can you advice the p/n of the aux. cable to use with my audio20.
Also please inform if instead i use an fm modulator with a 12v charger for my ipod nano 3rd gen. to connect to a free fm station,the quality will be acceptable.
Last,my car is equipped and wired with bluetooth telephony,please inform if i purchase the ipod kit b67824558 will it need programming?
Also regarding the aux. cable there is definetely no white plug by the passenger door [checked all cable assemblies],could it be connected at the backside of the audio 20 HU?
Looking forward for your help
Regards
LAKIS1961
Old May 30, 2012 | 03:08 AM
Kevwood's Avatar
'05 C200K SS, '05 Kleemann CLK500K, '08 Hummer H3 & '92 Z34 5sp (track car in Canada)
A 210 440 50 05 64
Very easy 30 minute install.
Old May 30, 2012 | 12:29 PM
pedcat's Avatar
2005 CLK55
Have another look for the white plug in the passenger door sill, mine was buried under other cables and close to the footwell.
Old Jun 1, 2012 | 03:51 PM
LAKIS1961's Avatar
2007 clk200
AUX cable clk200 2007 audio20
thanks for the p/n kenwood.
Please advise where does the cable connects[behind the audio20 or to the white plug by the door sill].Please bear in mind that after dismantling everything by the passenger door i couldn't find this plug.
Any photos or instructions for installing the aux. cable will be appreciated.
Regards
LAKIS
Old Jun 1, 2012 | 04:28 PM
pedcat's Avatar
2005 CLK55
Auxiliary install help on 07 clk350
DIY AUX input to connect an IPOD for only $10 USD
Old Jun 12, 2012 | 10:19 AM
LAKIS1961's Avatar
2007 clk200
aux. plug
Hi again,
It is definite that there is NO white or other free plug to connect the aux. cable for ipod to my audio20 by the pasenger door sill or footstep.
Any further help will be appreciated.
Regards
Lakis
Old Jun 13, 2012 | 04:24 AM
grech's Avatar
Mercedes CLK280 2007
Originally Posted by LAKIS1961
Hi again,
Regards
Lakis
I have a 2007 CLK280, and I also spent a lot of time looking for the white connector in the passenger side door, and couldnt find it. But as I knew that the AUX function is there (headunit shows AUX), the only other option was looking at the back of the headunit. And it worked
Basically, you have to open up the dashboard, starting from around the gear shifter, then the ashtray, then AC controls, then the top buttons panels, to expose the 4 screws that mount the headunit (2 on top, 2 on bottom). Below I'm attaching some mediocre pictures for any help (it was dark and I was working alone, along with holding a flashlight lol).
Once the headunit is out (you wont be able to pull it out too much since its got other wires connected, and there isnt any need to either), if you're looking straight at the back of the headunit, there is a big (i think theyre called quadlock) connector on the top right. One end of the AUX connector goes in here. At this point, I turned the car to ACC to check if the AUX worked and if I had plugged into the right spot, and I did.
Instead of trying to get the other side of the AUX connector (the side in which you plug in the AUX wire) into my glove compartment, I just let it be behind the headunit, plugged in the AUX wire (see the white Belkin wire), and ran the wire behind the dashboard, then under the gear shifter, through a small pre-made hole in the arm rest compartment. This way I didnt have a wire hanging out of glove box, and I could plug in the music player and keep it in the arm rest box.
Hope this helps. I'm a terrible DIYer and probably could have done a lot cleaner job, but at least it worked.
Some pics:
Old Jun 13, 2012 | 06:47 AM
Kevwood's Avatar
Great write-up man!
Old Jun 13, 2012 | 08:25 AM
LAKIS1961's Avatar
2007 clk200
Thanks grench
Is it possible to give the part no. of the aux. cable
Regards
Lakis
Old Jun 13, 2012 | 01:45 PM
grech's Avatar
Thanks Kev!
I don't know the Mercedes part number tbh. I ordered my wire from a UK website:
http://www.comandonline.co.uk/mb_aux_ntg2.html
Where do you live?
