Any way to increase seat fan cooling?
Is there a replacement fan that is more efficient?
I have a 2008 clk350 convertible with a heat/fan contour seat I bought out of an 09 and had installed. The contour was the important upgrade as I had heat, but the fan was a bonus.
Now that its hooked up and working, it doesn't feel like its doing much.
Any suggestions for improvements?
Thanks,
Dan
totally useless option. Im glad I got mine CPO because if I paid near $1k large for this option...I'd be pissed!
I've taken my car to the dealer under warranty to complain that the fan was not working and got to talk to the tech that specialized in seats. It turns out that they had to replace one of the upper bladders in the contour seat, but I talked to him about the cooling and he basically said that this is the way it works. If you listen carefully you can hear the fan run, but there is no output. this is the way they are designed it... I thought my VW was weak, but this is really nothing more than blue lights on a button in the dash.
On my Buddies Escalade and my Brother's Lincoln, your butt gets seriously cold. On my MBZ, it is nothing. If it makes you feel any better, my boss just got a new 2012 E350 'vert. I helped him order it, so it is fully loaded - including the contour and cooled seats. They don't work any better than ours
I like the way if you leave the car sitting in the sun, when you start the car - the seat coolers start automatically...like they actually do something... /end rant.
My car doesn't have heated or cooled seats. I am more interested in the heating part and had considered a retro fit. I presume the wiring is already there.
+ these fans:
http://www.digikey.com/product-detai...850528?cur=USD
(4 lead, but you only need black/red. I snipped the others)
+ 4" PVC piping cut into a 1/2" thick ring. Helps give some room between the fan blades and the seat back.
I've done both seats in my car like that. The upper 2 fans in the seat back.
If your back is sweating is helps. Otherwise, its still not a huge improvement.
Looks like everyone is modding the back but not the bottom.
Nice to know that the air is blowing the wrong way too <G>.
You've given me the information I need to move forward.
Just one question.
I noticed the fans you used are PWM.
Is their any significance or value to that?
Thanks,
Dan
My fans are set to blow air towards my back.
PWM doesn't matter, I snipped those wires off. Voltage is controlled by the dash switch. You can probably use a 80 or 92mm computer fan if you have some around. Its just a 12v fan.
