"Check oil level" indash message
Old Jul 3, 2012 | 10:35 AM
fusionnrg's Avatar
CLK 350
i keep getting this warning on my dash. i checked the oil level and everything looks fine. any other ideas? bad sensor?
Old Jul 3, 2012 | 11:33 AM
Glyn M Ruck's Avatar
Super Moderator
Bad sensor. It happens from time to time.
Old Jul 3, 2012 | 11:56 AM
fusionnrg's Avatar
CLK 350
thank you. has anyone had this same issue?
Old Jul 3, 2012 | 05:08 PM
Super Moderator
We have had a few on the W203 forum. Not sure here.
Old Jul 3, 2012 | 06:06 PM
Mka77's Avatar
06 CLK350 -SOLD! 2010 Cadillac SRX Premium Turbo
Haven't seen any threads around here about this...
Old Jul 12, 2012 | 10:58 AM
fusionnrg's Avatar
CLK 350
ok. so just to give everyone an update. took the car to the dealership. turns out it was the oil sensor that was bad. will be replaced through warranty.
i will post up more info about this issue when i pick up the car.
Old Jul 12, 2012 | 11:20 AM
Super Moderator
Thanks for coming back.
Old Jul 13, 2012 | 09:50 AM
fusionnrg's Avatar
CLK 350
So here is the notes on my invoice. no charge since it was covered under warranty.
faulty oil level sensor unit warranty. checked coding in cluster, checked oil level and found ok. Remove and install underpanel and replaced oil subpan and oil level sensor with new part. replaced pan due to warpage during removal. cleaned old silicone and applied new silicone before installing onto vehicle. checked for leaks and test drive.
