Ohms: What does "at or near zero" mean?
Also, if I get from 0 to 2 ohms with the ignition off, but about 5 with the ignition on, what causes that change?
Confession: This is my daughter's Audi, but I assume the principles are the same for any car.
You are testing the wire & not the sensor ~ Yes?
If the wire is isolated i.e unplugged at both ends it should read 0 Ohms or something is wrong such as a dry solder joint, badly crimped connector etc. If values are changing with ignition on then by definition this wire must be in circuit & we need to understand that circuit which means you are not in fact testing the wire.
Hope that helps.
However in an Automotive wiring harness even the longest conductor will have a resistance of close to zero of the sort of order you indicate.
Generally speaking, if your using your meter to "ohm" something out, your looking for either continuity (up to a couple of ohms) or lack of continuity (on a Fluke meter this is usually displayed as OL). 99 times out of a 100, you only care if you have continuity or no continuity.
The easiest test to demonstrate what I am talking about is to turn the meter on and set it to measure Ohms. You will see an "open" circuit indicated by OL or whatever your brand of meter uses to indicate an infinite resistance. Now short the two test leads together. You will now see somewhere around an ohm depending on how good of a connection your making between the two test probes.
