Please check my VIN for Balance shaft issue?
Rating: Thread Rating: 8 votes, 5.00 average.
Old Oct 5, 2013 | 01:21 AM
  #351
papadou's Avatar
CLK 350 Cabrio
Originally Posted by Rudeney
Yep, those codes are the tell-tale symptoms of balance shaft failure. It will continue to get worse until the MIL is constantly illuminated. The repair is around $5K (some dealers charging even more). My advice is to either get ready to pay that or sell it NOW before the MIL comes on.
Just thought I'd give an update on my situation. Took the vehicle to MB dealer with information in hand (ODB codes, service records, balance shaft bulletin, etc.). The vehicle was Certified Used purchased from that dealer. Long story short, they confirmed I have a balance shaft issue, MB Canada offered to pay 75% of the repair. Given that this vehicle is out of warranty and they could have told me to stuff it, I took the offer. If briefly considered trying to negotiate for more, but decided to cut my losses and get this done. $1.2k is much better than $5k.
Old Oct 5, 2013 | 03:05 PM
  #352
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Did you purchase the car from that dealer? If so, I'd remind them of that and ask them to help you out with the other 25%. $1200 isn't bad, but $0 or even $600 is better!
Old Oct 9, 2013 | 02:57 PM
  #353
rostrom's Avatar
2013 ML350, 2006 SLK280
I have a 2006 R350 with 118,000 miles and took it in to the dealer for recall work to be done replacing the cam shaft adjuster magentas and wire harness. I had a p0016 code and they said recall work did not fix it. It is the balance shaft gear. I was prepared for them to tell me $6k to fix, but instead the service advisor said "We are fixing it under warranty so give us 3 more days." I was floored. Certainly Mercedes seems to be slowly changing their stance on fixing this defect.
Old Oct 9, 2013 | 07:39 PM
  #354
RCorney17's Avatar
2007 GL450, 2003 BMW 325i
rostrom; that's outstanding news!
Reading back in my service records from my dealer, I noticed they replaced the solenoid wiring harness under an open campaign while doing an express lube oil and filter... maybe there's hope for me. (The wife is already shopping for a Tahoe ... grr.) And, while I was investigating the cam magnets myslef, I noticed a loose bolt for one on the passenger side. I wonder if that is tell-tale of them doing more than replacing the wiring harness?
Old Oct 9, 2013 | 10:36 PM
  #355
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
It seems there is much disparity in the balance shaft repairs being covered goodwill or not. I know of two people who have been turned down for this and their cars had lower miles. Are you the original owner and do you use that dealer for all of your work? If so, that seems to be a deciding factor. The dealers have a great deal of input when it comes to persuading MBUSA to cover repairs under goodwill.
Old Oct 10, 2013 | 08:55 AM
  #356
rostrom's Avatar
No, I'm not the original owner (I bought it 1 yr old with 9k miles) and I don't even use the dealer very often once my cars are out of warranty. I do regular maintenance myself and use and indy repair shop for most repairs.
The only thing I can think of is about 3 years ago I had the dealer doing some minor work and they found a small oil leak due to a bad plug of some sort. Today I realized that this may have been the wire harness that is now under recall. I'll try to find my documentation, but I recall it costing a good bit of money. Maybe they are doing this for me because I paid for a repair that later was part of a recall?
Old Oct 10, 2013 | 08:34 PM
  #357
ninsei's Avatar
2007 clk 550
Hi. Thinking of buying this 2008 clk550, would some kind MBWorlder pls chk this VIN for balance shaft failure susceptibility: WDBTK72G88T095426
Old Oct 10, 2013 | 11:17 PM
  #358
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Well, I am very surprised this dealer went to bat for you. Normally, getting a balance shaft replaced out of warranty can be an uphill struggle, requiring the dealer to convince the regional MBUSA reps to pay for it, and sometime the dealers have to cut in some, too, by taking a lower labor rate.
What dealer was this? I think it's worth a mention since they did you a favor!
Old Oct 10, 2013 | 11:19 PM
  #359
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
WDBTK72G88T095426 has M273 engine #215863. As expected with a MY2008, that's well beyond the affected range.
Old Oct 12, 2013 | 01:18 PM
  #360
ninsei's Avatar
2007 clk 550
Hi. Would someone mind checking if this VIN (from a 2007 CLK 550 I want to buy) is susceptible: WDBTK72F87T079099
Old Oct 13, 2013 | 12:10 AM
  #361
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
WDBTK72F87T079099 has M273 engine #86658, which is in the affected range for potential problems with the timing chain idler gear. y recommendation for prospective buyers is to avoid engine in the range unless you get a huge discount - like $4K or more below KBB trade-in value.
Old Oct 13, 2013 | 08:28 AM
  #362
ninsei's Avatar
2007 clk 550
Thanks you.
Old Oct 13, 2013 | 10:26 AM
  #363
ninsei's Avatar
2007 clk 550
can someone pls chk this 07 WDBTK72F47T076622
Old Oct 13, 2013 | 11:34 AM
  #364
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
WDBTK72F47T076622 is in the affected range, too - engine #63914. You're looking for a V8 engine after #30-88611 or a V6 after #30-468993. Unfortunately, you can't tell just by looking at a VIN range - you have to plug the VIN into EPC to get the build data showing the engine serial number. I don't mind at all doing lookups, but if you get into a spot where you "need it now" to make a decisiojn and I'm not online, you can use this site:
Russian EPC
Unless you speak Russian, I suggest using a browser that supports translations (like Google Chrome). Just plug your VIN into the text box, click the button to the right, then on the next screen, click the button on the top right side. If there is button on the top right, then it does not have the datacard for that vehicle. I think that's because it's only good through MY2011, but that is fine for balance shaft checks as anything as of MY2008 or later would not be affected anyhow.
Old Oct 15, 2013 | 01:26 PM
  #365
rj4pr's Avatar
E350
Is there a site where I can go to see if I will have an issue with my E350 if I buy it, or can anyone tell me?
VIN - WDBUF87J56X189353
Old Oct 15, 2013 | 04:38 PM
  #366
chopperpilot's Avatar
2007 Mercedes ML350, 1999 ML430
That 2005 E350 has a 272 engine number 112681. Unless you can document that it has been already repaired, I'd avoid it like the plague.
Old Oct 15, 2013 | 10:01 PM
  #367
rj4pr's Avatar
E350
Please check this VIN for Balance Cam Issues as I feel I am buying this car.
WDBUF56X09B419984
Old Oct 16, 2013 | 10:26 PM
  #368
shuazay's Avatar
Audi A3
Please check my VIN
Will you please check this VIN for a 2008 CLK550 WDBTK72F48T094233 we're wanting to buy? Thanks for looking out for all of us!
Old Oct 21, 2013 | 02:14 PM
  #369
mircea.anghel's Avatar
Honda Accord 2.oi
Hello. This is the VIN for a 2008 MB C280, can you check please? WDD2040811F270176
Thank you very much!
Old Oct 22, 2013 | 12:29 AM
  #370
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
WDD2040811F270176 has M272 engine # 31-125438, which is well beyond the affect range for balance shaft or cam sensor problems.
Old Oct 23, 2013 | 08:29 AM
  #371
Berwood's Avatar
2007 CLK 350
Here is WDBTK72F48T094233 https://www.epicvin.com/en/check-vin...TK72F48T094233
Old Oct 23, 2013 | 10:29 PM
  #372
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
WDBTK72F48T094233 has M273 engine #205343 - well bryond the affected range, as expected with a MY2008.
Old Oct 24, 2013 | 02:37 PM
  #373
mikats's Avatar
2006 c230
Was considering buying a used 2006 C 230 with 115k miles.
Now not sure. Can anyone tell me if VIN# WDBRF52H46E022051 would be one of these affected cars with the balance shaft issue?
The OBD is giving the P0012 code along with three others.
Thanks, am getting a real education on this site.
Old Oct 25, 2013 | 12:19 AM
  #374
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
WDBRF52H46E022051 has M272 engine #272980, which is in the range for potential balance shaft failure 9as will be all MY2006s and half the My2007s). The P0012 code is indicative of camshaft sensor magnet failure, which is an easy job, and about $100 in parts. The codes to look out for are P0016 and P0017, but my advice is to pass on any car in the affected range for balance shaft problems.
Old Oct 25, 2013 | 06:51 AM
  #375
mikats's Avatar
2006 c230
Thanks, would there be any way to know if the repair has been done?
You have already rated this thread Rating: Thread Rating: 8 votes, 5.00 average.
