Please check my VIN for Balance shaft issue?
Old Jan 19, 2014 | 10:29 AM
  #476
xsever's Avatar
2012 C300 4MATIC Sport
Originally Posted by CMW1077
I am considering buying a 2007 Mercedes Benz c280 4matic - WDBRF92HX7F876643 - could someone check the VIN and let me know if I will experience potential balance shaft failure. Thank you
Engine serial number is 479566 beyond the range of affected engines (up to 468993) so you are fine pertaining to the balance shaft issue.
Old Jan 19, 2014 | 02:35 PM
  #477
CMW1077's Avatar
Does this mean I will not have a balance shaft problem?
Old Jan 19, 2014 | 03:07 PM
  #478
xsever's Avatar
Based on the serial number, you shouldn't have it.
Old Jan 19, 2014 | 04:57 PM
  #479
CMW1077's Avatar
Balance Shaft Problem
I am looking at a 2005 Mercedes C240 VINWDBRF81J05F641213. Potential balance shaft issues? Thanks
Old Jan 20, 2014 | 05:54 PM
  #480
CMW1077's Avatar
Can someone let me know if this VIN falls within those that experience that balance shaft problem - thanks again
Old Jan 20, 2014 | 11:23 PM
  #481
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
WDBRF92HX7F876643 has M272 engine #479566. That is beyond the range for potential balance shaft failure.
Old Jan 21, 2014 | 11:36 PM
  #482
CMW1077's Avatar
Rodney thank you.
I am also looking at a I am looking at a 2005 Mercedes C240 VINWDBRF81J05F641213. Does this model also have a balance shaft issues? If so could you let me know if this particular vehicle is likely exposed to this issue based on the VIN? Thanks again.
Old Jan 21, 2014 | 11:38 PM
  #483
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
No, the C240 uses the M112 engine. A MY2005 C240 should be a great car - solid M112 engine and 722.6 transmission, plus it's the "facelift" interior which is a bit nicer.
Old Jan 22, 2014 | 12:55 PM
  #484
Bentz's Benz's Avatar
2007 CLK 550
Can WDBTJ72HX7F212058 be checked please? Thank you.
Edit - Damn, it appears to be in the range.
Old Jan 22, 2014 | 10:47 PM
  #485
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Yep, M273 #71246 is in the range. Are you having any issues? Pull codes and see if you have P0016/P0017 - yours could be fine as only a small percentage actually fail.
Old Jan 22, 2014 | 11:00 PM
  #486
2007 CLK 550
No issues, that particular car is a possible upcoming purchase. I'll be sure to bring my OBDII bluetooth dongle. Does the smart phone app Torque work with these cars? Thank you for your help.
Old Jan 22, 2014 | 11:12 PM
  #487
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Oh, if you are buying, my advice is this: If buying from an MBZ dealer, get them to promise in writing that they will cover the repair if it fails within 150K total vehicle miles. If you are buying elsewhere, negotiate and only buy if you can bank about $4K compared to a comparable car not in the affected range. Otherwise, skip it and find one not in range.
Old Jan 22, 2014 | 11:52 PM
  #488
2007 CLK 550
Thank you for your advice. I'll be buying it from Carmax and they have their three day return policy plus I'll be getting their excellent (from my own experience with an '05 GTO) warranty. If there's any codes, it's straight to the MB dealer.
Really looking forward to this, as it will be my first car paid for in cash. No more monthly payments for this guy.
PS - Is there any way to tell which paint code the car has from the VIN? All I know is that it's black.
Old Jan 23, 2014 | 09:30 PM
  #489
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
The paint code is "040" which is plain, non-metallic black. Here's the full data card:
http://benzbits.com/WDBTJ72HX7F212058.pdf
Old Jan 23, 2014 | 09:54 PM
  #490
2007 CLK 550
Thank you sir, very informative. Anything seem unique about that car? Seems like a standard CLK 550 with P1 package, but my knowledge of unique Mercedes isn't up to snuff yet.
Old Jan 24, 2014 | 10:31 PM
  #491
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Yep, that's pretty much it - CLK550 + P1.
Old Jan 27, 2014 | 01:58 PM
  #492
dubdlux's Avatar
'09 C350
Hi Rodney - do you mind checking VIN WDBUF87X48B238014 for me?
Thanks so much in advance!
Old Jan 27, 2014 | 09:28 PM
  #493
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Well, WDBUF87X48B238014 is a MY2008 so I am sure you have no worries with it in regards to the balance shaft, but just in case - it's M272 engine #753513, which is well beyond the affected range.
Old Jan 28, 2014 | 09:24 AM
  #494
randomperson's Avatar
clk 320 2003
Looking at buying a 2004 clk 500 with amg option. Vin WDBTJ75J84F118142, anything bad there? Also what should I check on this model before buying. Only has 69km and two owners here in Canada.
Old Jan 28, 2014 | 10:34 AM
  #495
dubdlux's Avatar
'09 C350
Thank you, Rodney!!
Old Jan 28, 2014 | 10:56 PM
  #496
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
I think you asked this on benzworld and I posted the datacard link there. A MY2004 should be a good car. Check the valve covers for oil leaks, but even so, that's an easy fix. Check the transmission electrical connector for leaks, but again, an inexpensive repair (maybe good to couple that with with a fluid and filter change for the transmission). Other than the typical wear/tear to look for on a 10+ year old car, everything else should be good.
Old Jan 29, 2014 | 10:09 AM
  #497
vavee's Avatar
08 r350 4matic
2008 Mercedes R350 4matic
Hey Rodney,
I have read almost all of your posts....good stuff alot of great info. I have a 2008 Mercedes R350 4 matic. My indy tells me that the timing solenoid magnets are bad (all 4) he also says that the intake manifold needs to be replaced and that "there are many other codes showing up". My VIN is 4JGCB65E08A070176. Do you think this would have anything to do with the balance shaft issues on these cars, and does my vin fall in the range?
I appreciate your help!
Ray
Old Jan 29, 2014 | 11:01 AM
  #498
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Your R350 has M272 engine #754155, which as expected with a MY2008 is beyond the range for balance shaft issues. But, it is still in the range for troubles witht he camshaft adjuster solenoids (a.k.a. "cam magnets"). These parts are about $100 for all four, and the labor is maybe 2 hours (and a fairly simple DIY if you are so inclined). This is covered in the TSB under "Scenario 2". Some dealers will cover this under goodwill. As for the intake manifold, there are some reports of failure with it, either cracks or broken actuators for the variable-length baffles. The manifold does have to be replaced as an entire unit, though some enterprising DIYers have repaired the broken parts themselves. My only caution about that repair is there have been reports of broken manifold pieces entering the engine combustion chamber and causing sever problems.
Old Feb 3, 2014 | 06:10 AM
  #499
CCQ25's Avatar
c230
Hi Rodney, I am considering buying VIN #: WDBRF52H47F881670 and was wondering if this car would be in range for the balance shaft issues. Any other words of wisdom to be on the look for as well would be greatly appreciated. Thanks in advance!
Old Feb 3, 2014 | 11:13 AM
  #500
NorthernVA's Avatar
2006 E55 - Eurocharged Stage 1
Rodney,
Thanks so much for providing us this information. If you wouldn't mind, could you please look up my automobile. It is a 2007 CLK 550
You have already rated this thread Rating: Thread Rating: 8 votes, 5.00 average.
