Please check my VIN for Balance shaft issue?
Old Feb 3, 2014 | 10:05 PM
  #501
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Originally Posted by CCQ25
Hi Rodney, I am considering buying VIN #: WDBRF52H47F881670 and was wondering if this car would be in range for the balance shaft issues. Any other words of wisdom to be on the look for as well would be greatly appreciated. Thanks in advance!
That C230 has M272 engine #497830, which is beyond the range (through 468993) for balance shaft problems. I don't like the earlier 722.9 transmissions like that one will have, but there's not much else to worry about. just read the forums and see what sorts of issues people have like intake manifold trouble, suspension maintenance, tires, etc. and decide if that's what you want to get into with a nearly 9 year old car.
Old Feb 3, 2014 | 10:08 PM
  #502
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Post
Originally Posted by NorthernVA
Rodney,
Thanks so much for providing us this information. If you wouldn't mind, could you please look up my automobile. It is a 2007 CLK550
Vin is: WDBTJ72H67F207472
Thanks again, Matt
Matt, yours has M273 engine #55501, which is in the range for potential timing chain idler sprocket failure. I recommend getting a cheap generic OBDII scanner and check weekly for P0016 and P0017 codes.
Old Feb 3, 2014 | 10:26 PM
  #503
NorthernVA's Avatar
2006 E55 - Eurocharged Stage 1
Rodney,
Thanks for the info, is it clear for balance shaft issues?
Old Feb 3, 2014 | 11:56 PM
  #504
jscoggan's Avatar
want a clk
I am considering buying this car, can you let me know if there is anything I should be looking out for that comes up in whatever program your using?
WDBTK75G54T020592
Old Feb 4, 2014 | 02:06 AM
  #505
CCQ25's Avatar
c230
Thank you so much Rodney. I truly appreciate the assistance, and will continue reading these forums about any intake manifold, or suspension issues, . . . but am relieved we are beyond the balance shaft concern. You rock!
Old Feb 4, 2014 | 10:49 PM
  #506
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Rodney,
Matt,
On V6 engines, a balance shaft is used to reduce engine vibrations inherent in that cylinder configuration. It's basically a shaft inside the engine block, parallel to the cranhaft with offsetting weights. It is drive by the center idler sprocket on the timing chain. The sprocket is just a forged part of the balance shaft. V8 engines are by design balanced and do not need a balance shaft. Their center idler sprocket for the timing gear is just bolted to the front of the engine block, inside the timing case.
The "balance shaft" failure is not actually a problem with the balance shaft itself, but is a failure of that center idler sprocket. On the V6, the repair requires replacing the balance shaft as it is all one forged part, but ont he V8, it;s gust the gear.
Unfortunately, your V8 is in the range for potential failure of this sprocket. Keep in mind that it may never be a problem as only a small percentage in the range have had problems. It seems the issue was improper heat hardening of the metal, but not all were affected. Maybe it was the "Thursday" parts, only the ones in oven #6 or those that "Bob" made. At any rate, plenty of cars never have the problem. Some people suggest that if you go over 100K miles with no problems, that you can breathe easy, but I have heard reports of a few that did show up then, but right over 100K. My advice is to get an OBDII scanner (any cheap one will work) and then check weekly for P0016 and P0017. They can be stored even if the MIL is not illuminated.
Old Feb 4, 2014 | 10:52 PM
  #507
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
WDBTK75G54T020592
That's a MY2004 CLK500. It's M113 engine would not have any issues with the "balance shaft". Also it has the 722.6 5-speed transmission which is very reliable compared tot he newer 722.8 7GTRONIC. There are a few minor issues to look for like leaky head/valve cover gaskets, but that's about it.
  #508
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Glad to help!
Old Feb 5, 2014 | 06:04 PM
  #509
Jhagan's Avatar
E350W 4matic
Rodney, could you check my (new to me) 2008 E350 4matic for any affected issues?
WDBUF87X78B344697
Thank you so much for your help
Old Feb 5, 2014 | 09:47 PM
  #510
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
WDBUF87X78B344697 has M272 engine #964680, which as expected with a MY2008, is beyond the range for balance shaft issues. it is also beyond the range for "cam magnet" failure.
Old Feb 6, 2014 | 10:59 AM
  #511
Jhagan's Avatar
E350W 4matic
Thank you Rodney for this wonderful service and the quick response!
Old Feb 6, 2014 | 11:25 AM
  #512
ericinchina4's Avatar
W220 S320
Hi Rudeny.
Old Feb 7, 2014 | 10:59 AM
  #513
vavee's Avatar
08 r350 4matic
Cam Adjuster Solenoids TSB
Originally Posted by Rudeney
Your R350 has M272 engine #754155, which as expected with a MY2008 is beyond the range for balance shaft issues. But, it is still in the range for troubles witht he camshaft adjuster solenoids (a.k.a. "cam magnets"). These parts are about $100 for all four, and the labor is maybe 2 hours (and a fairly simple DIY if you are so inclined). This is covered in the TSB under "Scenario 2". Some dealers will cover this under goodwill. As for the intake manifold, there are some reports of failure with it, either cracks or broken actuators for the variable-length baffles. The manifold does have to be replaced as an entire unit, though some enterprising DIYers have repaired the broken parts themselves. My only caution about that repair is there have been reports of broken manifold pieces entering the engine combustion chamber and causing sever problems.
Thanks Rodney. I have called my MB dealer and they said they do have an open campaign open for the cam solenoids - which they explained to be just a wiring issue...?? Not sure if they are owing up to the magnets yet...that said I do think I have a bit of an oil leak (very slight one) - could it be all connected to the adjuster solenoids?
Thanks again for your help....!!!
Old Feb 7, 2014 | 11:26 PM
  #514
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
The oil leak is "Scenario 3" on the TSB. The replacement solenoids to fix Scenario #2 have new seals which which thus fixes Scenario #3.
Old Feb 9, 2014 | 04:45 PM
  #515
rmars's Avatar
2002 Mercedes S500 (w220)
WDBTJ72HX7F212058 please help break down this vin# I'm looking to purchase a 2007 CLK550 but not sure if the engine number is past the idler gear issue - I just don't understand if its the last six digits or for example this engine # is 67 071246 and it states engines 30.. are effect please help - when decoding the VIN# im getting engine number 30 273 967 071 246
from mercedes bulletin:
Applicable Models (Not Applicable to Model 164.156, 204 or 216.386): Equipped with M272 Engine Up to Serial No. 2729..30 468993 or M273 Engine Up to Serial No. 2739..30 088611.
The material for the balance shaft sprocket and the timing chain guide wheel (idler) was modified on engines past the serial numbers listed above.
Old Feb 9, 2014 | 10:00 PM
  #516
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
I believe this was answered for you over on benzworld, but yes, that engine is in the affected range for potential sprocket failure.
Old Feb 10, 2014 | 12:17 PM
  #517
rafiwadud's Avatar
CLK350 2007
Rudeney,
Can you check WDBTJ56H07F216196, help me figure out if I need a "rainy day fund"
Old Feb 10, 2014 | 10:05 PM
  #518
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Good news - WDBTJ56H07F216196 has M272 engine #500162, which is beyond the range for balance shaft issues. It may still have camshaft solenoid problems, but that's easy & cheap to fix.
Old Feb 10, 2014 | 10:57 PM
  #519
rafiwadud's Avatar
CLK350 2007
Score! I remember reading a class action law suit against Mercedes for it and it included the clks. Couldn't remember if mine fell in the range.
Back to driving in snow with my ESP off lol... jk time to add some mods i wanted finally
Old Feb 11, 2014 | 09:26 PM
  #520
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
The CLK is most certainly susceptible to "balance shaft failure" as it uses the M272 and M273 engines. Any MBZ model with the M272 or M273 engine in the affected range can fail. The lawyers that drew up the class action lawsuit were ignorant and that is one of the reasons ti was thrown out of court.
Old Feb 12, 2014 | 03:51 AM
  #521
iamkimosabi's Avatar
C300 W204 Luxury
Hello Rodney, can you please check my 2008 c300 for me? Thank you sir.
-tong
WDDGF54X78F105764
Old Feb 12, 2014 | 09:43 PM
  #522
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
WDDGF54X78F105764 is in the clear as expected with a MY2008 it has M272 engine #836231, which is beyond the balance shaft problem range. All W204's should be clear.
Old Feb 15, 2014 | 10:57 AM
  #523
Sean Ong's Avatar
Mazda 6
Hi Rodney,
Kindly help check these 2units of E280 2007 which I interested to purchase; are they in the range for potential timing chain idler sprocket failure?
WDD2110546L004424 Engine 27294330458075
WDD2110546L004446 Engine 27294330458097
Thanks so much for your wonderful services!
Regards,
Sean
Old Feb 15, 2014 | 12:18 PM
  #524
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Hi Sean, both of those are in the range for potential failure. Any M272 engine up to #468993 and any M273 engine up to #88611 are in the range.
FYI, these engine serial numbers are in the format of M27a9bb3cdddddd. "a" is "2' for the V6 model and "3" for the V8. "bb" is a sub-part number differentiating the different displacement size (These engines were built in ranges from 2.5l to 5.5l). "c" can really just be though of as the 7th digit of the serial number ("dddddd"). So, when I say "up to engine #468993, it means up to "M2729xx30468993" and up to 88611 is "M2739xx30088611".
Old Feb 15, 2014 | 01:04 PM
  #525
Sean Ong's Avatar
Mazda 6
Thanks Rodney for your prompt reply & explaination on the format.
I'm wondering if all E280 built 2007 are affected...meaning I'll have to look at year 2008 for unaffected E280 ?
You have already rated this thread Rating: Thread Rating: 8 votes, 5.00 average.
