Please check my VIN for Balance shaft issue?
Rating: Thread Rating: 8 votes, 5.00 average.
Old Mar 15, 2014 | 11:02 PM
  #576
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
4JGBB86E39A528350 has M272 engine #31-224499. As expected with a MY2009, it's far beyond the affected range for balance shaft problems.
And just a note - I usually post engine serial numbers as six digits, but they are actually eight digits. The first series of M272 and M273 engines started with a "30" prefix and its those 30-000000 to 30-468993 (for the M272 V6) or 30-000000 to 30-088611 (for the M273 V8) that are affected.
Old Mar 15, 2014 | 11:14 PM
  #577
lobart's Avatar
2007 CL550 AMG/2008 ML550 AMG/1995 SL500
thanks Rodney,
I've been trying to use that Russian website but it doesn't always work...
Old Mar 16, 2014 | 01:18 PM
  #578
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Try this one:
http://www.auto-parts.spb.ru/cat/cat...&client=dr2000
I just put your VIN in and it has the data card.
I typically check VINs with EPC, which I have as part of SDS/WIS installed on my computer. My copy is good through MY2010.
Old Mar 19, 2014 | 09:59 PM
  #579
vastcre's Avatar
none
Rodney, you are the man.
I'm looking at a 2006 E350 with 62K miles, vin WDBUF56JX6A809584. Would you please let me know if this is in the range of balance shaft issues?
Thank you very much.
Old Mar 19, 2014 | 11:18 PM
  #580
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
WDBUF56JX6A809584 Yep - it's MY2006 so it will be in range for potential balance shaft failure. M272 engine #081542.
Old Mar 19, 2014 | 11:28 PM
  #581
vastcre's Avatar
none
Thank you so much. You just saved me from purchasing a $12K paper weight.
Old Mar 20, 2014 | 10:24 PM
  #582
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Just keep in mind, not all in the range will fail, but my advice is when buying why take a chance? Find one not in the range and sleep easier at night.
Old Mar 21, 2014 | 06:16 AM
  #583
MB Frenzy's Avatar
2007 E350
2006 Engine issue
Does WDBTK56G46T070907 fall in the potential engine issue
Old Mar 21, 2014 | 07:51 AM
  #584
Airmousam's Avatar
2010 E550 4M P2 Distronic, CLK550 Cab P2
Hi Rodney, Can you pls check this one. 2007 CLK 550
WDBTK72F47F222404
Thanks!!
Old Mar 21, 2014 | 08:33 AM
  #585
Airmousam's Avatar
WDBTK72F47F222404
Thanks!!
Found the motor number. Thx again
273967 30 120671
Old Mar 22, 2014 | 02:45 AM
  #586
fastneutron's Avatar
Obsidian Black C43, Silver C43, Silver Carlsson E-class wagon, Brabus G-class
Just sold the G500 and planning on buying a 2008 R350. Can you please check if VIN 4JGCB65E48AO81634 is affected?
Thanks so much.
Old Mar 22, 2014 | 11:48 AM
  #587
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
That car has M272 engine #332004 which is in the range for potential balance shaft failure.
Old Mar 22, 2014 | 11:50 AM
  #588
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
273967 30 120671
That engine is beyond the affected range (M273 problems end at #88611)
Old Mar 22, 2014 | 11:51 AM
  #589
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Thanks so much.
I can't get that VIN to pull up - maybe there is a digit wrong? But by MY2008, you should be fine - the problem was caught back in lat 20006, before the MY2008' went into production.
Old Mar 23, 2014 | 12:13 AM
  #590
4JGCB65E48A081634. I made a mistake. The character between A & 8 is zero not letter O. Please try again. Thanks a bunch.
Old Mar 23, 2014 | 01:41 AM
  #591
Please also check:
4JGCB65E28A078764 It's a MY2008. Thanks.
Old Mar 23, 2014 | 07:03 AM
  #592
Airmousam's Avatar
rodney, thx!!
Old Mar 23, 2014 | 01:45 PM
  #593
dbow2000's Avatar
'94 E320 '99 CLK320
Considering purchasing CLK350 with this VIN WDBTJ56JX6F196167 for my wife. Please check. Thanks!
Old Mar 23, 2014 | 02:33 PM
  #594
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
M272 #887775 - beyond the range for balance shaft failure.
Please also check:
M272 #845681 - also beyond the range.
The problem was identified and rectified in calendar year 2006, when they were about halfway through the MY2007. Very rarely does MBZ begin production two "model years" ahead, i.e. they would not have been building MY2008s during calendar year 2006. However, during new model introductions or even major facelifts, they do sometimes build "pre-production" models early. These vehicles are not normally sold to customers. They are usually destroyed, but I think sometimes, they fall into the "black market". I have heard of one MY2008 with an engine in the range, and I believe it was such a situation.
Old Mar 23, 2014 | 02:34 PM
  #595
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Yes, all MY2006'ws will be in the affected range - this one has M272 #321237.
Old Mar 23, 2014 | 06:32 PM
  #596
Thank you Rodney!
Old Mar 24, 2014 | 09:03 PM
  #597
bubarsmith's Avatar
2006 Mercedes Benz R350
What about VIN 4JGCB65EX6A028031 ?
Old Mar 25, 2014 | 12:19 AM
  #598
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
4JGCB65EX6A028031 is a MY2006 so yes, its M272 engine #3378808 is within the range for potential failure.
Old Mar 25, 2014 | 08:38 PM
  #599
godsman's Avatar
2006 SLK55 AMG 2007 CLK550 CAB 1983 SL380
I just bought a 2007 CLK550 with the VIN# WDBTK72F47T077396. Is this car affected...???
Old Mar 25, 2014 | 10:08 PM
  #600
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
WDBTK72F47T077396 has M273 engine #758854 which is in the range for potential balance shaft (or for the V8, timing chain idler sprocket) failure.
You have already rated this thread Rating: Thread Rating: 8 votes, 5.00 average.
