Please check my VIN for Balance shaft issue?
EDIT: my bad, the VIN numbers by the decoder and by car doccuments are diffrent, i guess the engine has been changed...
http://benzbits.com/datacard/WDD2193561A013324.pdf
It shows engine "272964 30 032216" Basically, you can think of the engine serial number as seen digits - the last seven of that engine number, so "0032216". The balance shaft problem range for the M272 is through 0468993 or "272xxx 30 468993". When that "30" changes to a "31" is just because the last six digits rolled over 999999.
VIN WDD2193561A011295 thanks
Repeatedly
My car is an 07/07 build so just worried that somehow bad idle gear parts got put into the car by accident even though engine serial on the VIN decode shows as beyond range for scenario 1.
So I noticed the adapter harnesses looked old. I removed the drivers side intake one and the plug that connects to the magnet had some play (would move up and down). So I tossed all 4 of the old adapter harnesses and got new ones (part number 271 150 01 56). The new ones look a tad bit different and the plugs seem more durable. I cleared the codes and no pending codes are showing up. So far so good so hopefully that solved it. Just wanted to share.
thanks
Can you please check if affected?
VIN: WDBTJ72J27F213241
Thanks,
ZZ
Thanks,
ZZ
