Please check my VIN for Balance shaft issue?
Old Dec 10, 2019 | 02:34 PM
  #1576
PaulyGee's Avatar
2007 E350, 2011 ML350, 2003 E320
Hi Guys, am just reading up on this dreaded Balance shaft issue and was hoping Rodney can help me out. My VIN is WDBUF56X97B062317, 2007 E350. Please let me know if my engine # falls under the affected ones? Thank you in advance, much appreciated.
Old Dec 10, 2019 | 11:33 PM
  #1577
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Beyond the problem range.
Old Jan 4, 2020 | 01:17 PM
  #1578
Victor Vassilev's Avatar
Mercedes C350 (s203)
Can you please check by VIN?
Hello all. Can someone check if this VIN belongs to a C350 2005 within the range of affected cars of the balance shaft issue for M272 engine ? wdb2032562f733480 Thank you.
Old Jan 5, 2020 | 11:54 AM
  #1579
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
No need to check - yes it will be in the range. All M272 and M273 engines prior to MY2007 are in the range, and about half of the MY2007's. After MY2007 are fine. So, only MY2007's need to be checked by VIN. Also, please understand the term "model year" which is different from "plate year" used by your country. Model year is the definitive standard the manufacturer uses to indicate a particular version/revision of a car. There is no such thing as a "MY2005" CLK350 - the CLK350 came out in mid calendar year 2005 as a MY2006.
Old Jan 21, 2020 | 10:53 PM
  #1580
vinsuz's Avatar
2007 CLK 550
Hi Again Rodney, it’s hard to believe this thread is still going strong seven years later, but thankfully so is the idler sprocket in my CLK550. I’m over 62k miles now, and while I had a couple of MILs a few years back, they always seemed to “go away” after a good old Italian tuneup (my car might be German but my name is Vinnie after all). I’ve had the stealership pull codes a couple of times over the years, but the only thing they ever found was the SRS error caused by me putting a full growler of beer on the front passenger seat while the car was moving! I did notice a slight squeak while idling, and even mentioned it to the service advisor when I took it in for an oil change, but they still didn’t find anything.
My question is, as the defective sprocket wears, don’t you think it would begin to become apparent because the timing would change? Or would it be so subtle as to render it undetectable to mere mortals? I’d like to think I got one of thecorrectly forged sprockets, but it’s always in the back of my mind, especially now because I’m starting to think about selling it (there have been quite a few reasonably priced SL55s and SL63s on Bringatrailer.com recently).
Thoughts?
Vin
Old Jan 22, 2020 | 09:58 PM
  #1581
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
When/if it first begins to fail, all you'll get is an MIL with 1200/1208 (P0017/P0016) codes. The variable-valve timing system can actually compensate for the slack in the timign chain caused by the work sprocket.
Old Feb 7, 2020 | 03:58 PM
  #1582
Rosta Stehno's Avatar
W204 C280 Avantgarde
Hi there, can you please check mine?
WDD2040541A023107
I have some problems now and some scary codes from diag appeared:
0064
2381
0629
0649
0637
Thanks ...
Old Feb 8, 2020 | 07:32 AM
  #1583
thecrazyone's Avatar
2006 E 350 4matic, 2003 C 240
i have an 06 e350 and new to Mercedes, would it be possible to find out if my engine is in the bad range? vin WDBUF87J76X197468
Old Feb 8, 2020 | 12:10 PM
  #1584
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
WDD2040541A023107
0064
2381
0629
0649
0637
Thanks ...
You have engine serial number 30-662950, which is beyond the range.
You can lookup the meaning of those codes here:
http://benzbits.com/dtc/DTC%20209.372.pdf
Old Feb 8, 2020 | 12:12 PM
  #1585
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
All MY2006 MBZ's with M272 (xx230,xx280, xx300, xx350) or M273 (xx450, xx550) engines will be in the range. Only MY2007 needs to be checked by engine serial nubmer/VIN. MY2008 and alter are all beyond the range.
Old Feb 9, 2020 | 02:59 AM
  #1586
Thanks a lot, I am less scared then beffore but the missfiring cilinder numbers are different to those given to me by the service.. The told me that this codes mean 4th and 2nd cylinder, but your table says its 5th and 6th ... I am little bit confused...
Old Feb 9, 2020 | 06:59 AM
  #1587
jepaul's Avatar
Veteran: Navy
2006 CLK 350 Cab
Wow, since this thread is still going strong . . . For my own clarification and ease of mind, from what I get in this thread is that the balance shaft may wear out prematurely because it was discovered that a proper heat treat was not done on some of them during production. There is no way to know exactly which ones but it is known what period of time these were presented for inclusion into MB engines. It is not absolutely certain my engine contains the weak part, only that it was produced at the range of time known to MB.
  • Knowing this, what can one expect as a sign of the issue manifesting itself?
  • Does it appear in cars driven harder, will the engine vibrate more, will engine light appear first, or will the engine simply seize?
  • Does it make sense to get it fixed now even though there are no signs of the problem and how much should it cost?
Old Feb 9, 2020 | 02:25 PM
  #1588
Originally Posted by jepaul
Wow, since this thread is still going strong . . . For my own clarification and ease of mind, foorm what I get in this thread is that the balance shaft may wear out prematurely because it was discovered that a proper heat treat was not done on some of them during production. There is no way to know exactly which ones but it is known what period of time these were presented for inclusion into MB engines. It is not absolutely certain my engine contains the weak part, only that it was produced at the range of time known to MB. Knowing this what can one expect as a sign of the issue manifesting itself? Does it appear in cars driven harder, will the engine vibrate more, will engine light appear first, or will the engine simply seize? Does it make sense to get it fixed now even though there are no signs of the problem and how much should it cost?
Its aournd 4 - 6k euro...
Old Mar 11, 2020 | 12:39 PM
  #1589
tekwaldo's Avatar
2006 E350
please check my vin
WDBUF56J06A767586
Old Mar 25, 2020 | 05:31 PM
  #1590
HamMan's Avatar
2015 E400 Cab - 2013 GL350 - 2013 ML350 - 2006 E350 - Old Jeep
I am just reading up on this dreaded Balance shaft issue and was hoping Rodney can help me out. My VIN isWDBTK56G06T063985
2006 CLK350. Please let me know if my engine # falls under the affected ones?
How would I know if this repair (if needed) had been completed at the dealer?
Old Apr 17, 2020 | 07:23 PM
  #1591
tkstyle's Avatar
Mercedes w220 s430 & Mercedes w126 280se
Hi dear MB friends,
Thank you so much in advance to check if I am also in the affected range seen from the famous issues like timing chain
2007 GL550
With the following VIN nr: 4JGBF86E08A325970
Old Apr 19, 2020 | 09:08 PM
  #1592
brouamba's Avatar
2006 C230 Sports
Hi, I have the dreaded Balance shaft issue on my 2006 C230 Sedan sport. MB dealer confirmed it and recommended I go to MBUSA. They said they couldn't discuss the terms of the settlement of the SEIFI case which started this whole repair thing, claimed the extended warranty period had expired and redirected me to a site that is no longer operational. In fact it's for sale: balanceshaftsettlement.com.
Can somebody tell me whether the warranty has really expired? Or is it just MBUSA saying this to scare people off? My reading of the settlement says it won't expire for a while (2025) as MB USA agreed to the settlement on March 23 2015 & it became effective in August of the same year. Does anybody have similar or different info. Please share?
Also if Rodney or sbdy else is still checking impacted vehicles based on the VIN - please check mine: WDBRF52H56F746700. Here are some key terms of the settlement
1)
“Defendant Mercedes-Benz USA, LLC (‘MBUSA’) prospectively [will] cover future repairs for the allegedly defective parts at issue for the lesser of 10 years or 125,000 miles, subject to certain conditions and limitations. This extended coverage more than doubles the durational limit of MBUSA’s New Vehicle Limited Warranty’s term of the lesser of 4 years of 50,000 miles.”
2) The Mercedes class action settlement is for “all current and former owners and lessees of Mercedes-Benz branded automobiles equipped with M272 or M273 engines bearing serial numbers up to 2729..30 468993 or 2739 ..30088611, found in the Subject 2005 – 2007 Model Year Vehicles respectively (the ‘Subject Vehicles’), who purchased or leased their Subject Vehicles within the United States.”
https://topclassactions.com/lawsuit-...ction-lawsuit/
https://topclassactions.com/lawsuit-...on-settlement/
https://topclassactions.com/lawsuit-...comment-224780
Old Apr 20, 2020 | 10:23 PM
  #1593
brouamba's Avatar
2006 C230 Sports
Rodney
Hi Rodney , Can you check my VIN WDBRF52H56F746700 C230 Sport Sedan
Is the settlement still active because MBUSA says it expired - would not confirm when ?
My reading of the settlement indicates it has not :
1) “Defendant Mercedes-Benz USA, LLC (‘MBUSA’) prospectively [will] cover future repairs for the allegedly defective parts at issue for the lesser of 10 years or 125,000 miles, subject to certain conditions and limitations. This extended coverage more than doubles the durational limit of MBUSA’s New Vehicle Limited Warranty’s term of the lesser of 4 years of 50,000 miles.” Agreed by MB March 23 2015
Old Apr 21, 2020 | 01:58 AM
  #1594
nkx1's Avatar
2010 E550 Coupe
Color me confused. If the settlement only covers 10 years or 125,000 miles, and you have a 2006 car, and you weren't a party to the class action suit, how or why would the car be covered under this settlement?
Old Apr 21, 2020 | 11:00 PM
  #1595
brouamba's Avatar
2006 C230 Sports
I guess it depends on the effective date of the settlement doesn't it rather than the age of the Car? I am no lawyer and I am coming to this late but that's how I understood it. I am happy to be enlightened that's why I am here asking questions. My information says MBUSA agreed to the settlement on Mar 23 2015. Doesn't that means the 10 years coverage start then for anyone who has not reached 125K miles ?
Old Apr 22, 2020 | 12:11 AM
  #1596
nkx1's Avatar
2010 E550 Coupe
I'm not a lawyer either, but the wording of the settlement is such that the coverage extends from the date of purchase, not the date of the settlement. The lesson here? Don't buy a Mercedes! (just kidding, sort of).
Old May 9, 2020 | 01:54 AM
  #1597
Aungmyat05's Avatar
2006 e350
Blance shaft replacement
Originally Posted by edm163
Contact me for any balance shaft repair in the NYC / NJ area. Will beat any price and job done in 3 days. All work GUARANTEED!
I have a 2006 e350 that needs the balance shaft replaced. Do you still do them? If so please contact me back!
Old Jun 29, 2020 | 10:57 AM
  #1598
kmontalv's Avatar
2008 Mercedes Benz E63
Please check my vin
Please check this vin # for balance shaft issue thanks!
WDBTK72F07T074852
Old Jul 16, 2020 | 10:16 AM
  #1599
Transmetal's Avatar
E320 4MATIC
New member here, I'm in the process of possibly buying an 05 E320 4Matic with only 38k. Was bought new by an older German Gentleman in his 80's. He drove it a little bit and had it serviced at the Benz dealer. He's since passed away. His wife wants to sell the car as it doesn't get driven much anymore. I called the local Benz dealer and they said they couldn't give me maintenance records unless I was the actual owner. The car doesn't have the airmatic suspension, which is a relief but I've been hearing about this balance shaft issue. Is the e320 affected? This is the vin number WDBUF82J75X165724 engine number 112954 31 838287. Hope I'm in the right place, if I'm not, please forgive me.
Old Aug 9, 2020 | 03:24 PM
  #1600
mulkeyc230's Avatar
c230
vin check on my c230
My check engine light is on and throwing code P0016, Can you please check my vin#WDBRF52HX7A931436.
It has 146,000 miles on. I purchased the car back in 2010, with 34,000 miles on it
Thank You
You have already rated this thread Rating: Thread Rating: 8 votes, 5.00 average.
