Please check my VIN for Balance shaft issue?
Old Dec 11, 2020 | 08:22 PM
  #1601
Prov's Avatar
2009 CLK550
Please check my vin for issues
Can someone check my vin for balance shaft issue and timing chain idler gear issue please.
2009 CLK 550
WDBTJ72H39F257538
Old Dec 12, 2020 | 07:37 AM
  #1602
Barclay Close's Avatar
2007 clk 350
Can someone run my vin to see if I am in or out of range of the issue please? Thanks. WDBTK56F67TD82968. I have had the car for 6 years but just now decided to use it as a daily driver. Currently it has 50K miles. Thank you in advance
Old Aug 28, 2021 | 07:02 PM
  #1603
migo11's Avatar
Mercedes Benz R350
pls can you check for my Mercedes-Benz for balance shaft issue
Pls check my 2007 Mercedes R350, vin number 4JGCB65E67A041568, and engine number 272967 30 448632
Old Aug 29, 2021 | 04:38 AM
  #1604
xsever's Avatar
2012 C300 4MATIC Sport
Applicable Models (Not Applicable to Model 164.156, 204 or 216.386): Equipped with M272 Engine Up to Serial No. 2729..30 468993
so yes your car is in the affected range
Old Oct 18, 2021 | 08:11 PM
  #1605
Tantz's Avatar
e320 wagon
Seeking Advice on this VIN/engine number, thanks!
@Rudeney Thanks for helping everyone here Rodney and others: Just finding this thread.. years later, wonder if anyone's still active in the conversation, as I am considering a 2006 e350 wagon, yet need help to discern if the engine is potentially effected by the balance shaft issue. VIN WDBUH87J06X191375 and I just went to the site as directed, and this is the engine number: Engine 272972 30 137802 and also an image attached ... would greatly appreciate any replies!! Or fair warnings if this potential purchase is too risky. Thank you! also @xsever
Old Oct 19, 2021 | 12:47 AM
  #1606
xsever's Avatar
Engine serial numbers up to 2729..30 468993 are affected so since your engine serial number is 137802, that means it is within the range.
Old Oct 19, 2021 | 12:14 PM
  #1607
Tantz's Avatar
e320 wagon
@xsever @rudeney thank you, are the prior wagons e320's safe? Or are later models (2004 for ex) also possibly effected? Or any other known red flags for the Wagon e320's? Thanks to anyone who has intel -- Tantz
Old Oct 23, 2021 | 05:01 AM
  #1608
xsever's Avatar
The 320s use the M112 engine which is not affected.
Old Oct 28, 2021 | 02:58 PM
  #1609
tam361's Avatar
2009 C300
Hi folks, I just joined today. I am looking at two cars to buy, both have the 2006 3.5L V6!
Could someone check to see if they are in the problem engine list please? Thank you so much!
Tam
2006 E350 VIN WDBUF56J46A826090
2006 ML350 VIN 4JGBB86E86A048932
Old Oct 28, 2021 | 09:52 PM
  #1610
dcm325's Avatar
E350
Vin check… 06 350 at 162k
WDBUF56J46A826090
Old Nov 3, 2021 | 08:09 AM
  #1611
Komp14's Avatar
W202
Hi guys, could you pleas kindly provide me with more information about WDD2210561A048552, is there any issue/ defect with the motor. is it problematic? Can you also provide me with more info about incidents with the car? Real km check until now? Thanks in advance!
Old Jul 31, 2022 | 02:54 AM
  #1612
Reva65's Avatar
E350
Balance shaft sprocket inquiry
Hi all, I am 24 hrs away from purchasing a 2007 Mercedes E350. Build Date June 2007. VIN WDBZ110562B138429.
Can someone please help me work out if this car is effected with the balance shaft sprocket issue?
Thank you all in advance.
Old Aug 1, 2022 | 03:27 AM
  #1613
Greg Northcott's Avatar
CLK350 Convertible 2007 W209
Originally Posted by chrono12
How about WDBTJ56H17F219334? The VIN Decoder doesn't list that, right? Or am I overlooking Engine #?
It goes off your engine S/N. Higher than 2729.30468993 is ok
Old Aug 1, 2022 | 03:29 AM
  #1614
Tam
Early M272 Engine is the problem. your fine
Old Aug 1, 2022 | 03:31 AM
  #1615
It goes off engine S/N. see my reply to chrono12
Old Aug 1, 2022 | 03:33 AM
  #1616
All ok from 2729.30468993
Old Aug 1, 2022 | 06:51 AM
  #1617
Reva65's Avatar
E350
Thanks Greg. The engine number is 272964 30611358.
So I guess by your information my engine number should have the upgraded part.
Old Aug 15, 2022 | 03:43 AM
  #1618
Dimboy's Avatar
E320 W211 (M112) - sold, CL500 C216 soon
Hello guys!
I apologize for posting this in the W209 forum however this thread is the most involved towards the M272 balance shaft & M273 idler gear issues and folks post about other cars than the CLK.
I am in the market for CL500 C216 with the M273 engine. I have targeted a specific car which I saw live a couple of days ago and next week we are meeting to have an independent shop make a full pre-purchase inspection. The owner of the car has supplied me with the VIN which I ran through a decoder to get the engine serial number. So far so good, however the serial number differs a slight bit from all M273 engine serial numbers posted in this thread and I couldn't find such scenario in all 65 pages which I read through in addition to many other threads & information in Google.
The VIN is: WDD2163711A003933
The engine serial number I get is: 273961 09 309363
As you can see the 6 digits (309363) seem to be way after the affected engines, but the 2 digits before them are not the usual "30" instead it's "09". I have seen another CL(Here's VIN for reference: WDD2163711A012327) with such engine serial number so I am not sure how to read it. One of Rudeney's explanations some pages back is that the 2 digits before the last 6 increment by 1 once the 6 digits surpass 999999, which on the M272 made sense as it went form "30" to "31". In my case though it seems to run backwards?
Do you guys have any idea how this should be interpreted and whether it falls in the affected M273 engines or I am safe?
Thanks in advance!
Old Aug 15, 2022 | 04:28 PM
  #1619
wagzbenz's Avatar
CLK 350A Cabriolet
Could someone check mine WDBTK56F78T092183
Old Sep 25, 2022 | 05:49 AM
  #1620
SilverCLK280's Avatar
2006 CLK 280 Elegance
CLK280
Originally Posted by Rudeney
Forget what the lawsuit listed - it was not correct in the models it included. Basically, any MBZ with an M272 or M273 engine could be affected if it falls within the serial number range. That includes the SLK280. The M272 V6 engine was available as a 2.5l (C230), 3.0 liter (C280, C300, SLK280, etc.) and 3.5l (C350, CLK350, E350, etc.) The M273 V8 engine was available as a 4.7l (GL450) and 5.5.l (CLK550, E500, SL550, etc.)
The TSB notes a few exclusion: the 164.156 (ML350 RWD, non-4MATIC), the W204 and the 216.386 (CL550 4MATIC). I believe these are excluded only because these models did not go into production until after the problem was identified and corrected.
WDBWK54F16F091252 is an SLK280 with M272 engine #135490 - that is in the range for potential balance shaft failure.
Rudeney please can you tell me if my 2006 CLK 280 falls into the range of affected potential balance shaft failure.
WDB2094542T070608
Thanks in advance 🙏
Old Oct 7, 2022 | 10:48 AM
  #1621
brianadicks's Avatar
2004 C270 CDi Auto Avantgarde
Please check my vin CLK 500 M273
Good day, can someone still check my vin nr WDB2093722F234244 for the balance shaft and other issues?
Old Dec 22, 2022 | 11:32 AM
  #1622
DM914's Avatar
none currently
Can someone in the know check this VIN for an engine that maybe effected by the issues WDBTK72F27T076778 it's a 2007 CLK550
Old Sep 11, 2023 | 08:37 PM
  #1623
luisp's Avatar
MB W203 C230
W203 balance shaft issues
Originally Posted by M888THM
Hi peops, is my mercs engine falls into this mess
272964 30 122557 2
Hi folks, I am about to buy a 2007 C230 with 185,000miles. Can someone tell me if this car is subjected to balance shaft problem ? Vin #WDBRF92H97F889951
Old Sep 12, 2023 | 02:41 AM
  #1624
nkx1's Avatar
2010 E550 Coupe
Old Sep 15, 2023 | 10:59 PM
  #1625
wagzbenz's Avatar
CLK 350A Cabriolet
Why do you gotta be a jerk? JERK
You have already rated this thread Rating: Thread Rating: 8 votes, 5.00 average.
