08 CLK 550 Transmission issues
The car will slam into 2nd. gear when in stop and go traffic. If you go wide open throttle from a standstill or rolling 10 or 20 mph it will defuel then run hard from 1st and then slam into 2nd gear and then pulls the power off quite a bit until it shifts to 3rd. Then it goes thru the rest normally.
We don't run it hard we are in our sixties. I was told at the time of service that the de fuel when kicking sown was normal. I used to spin wrenches for a living but only did brakes and such on M.B. products, but I'm guessing it is a bad shift solenoid or judging by the reduced power/limp in 2nd. gear that maybe the clutch packs are going south. Any idea's ? Thanks
I also almost never use the "C" mode. Though the car would start off in 2nd; have you used the "C" mode and if so, are the rest of the shifts ok?
BTW, I am in my 60's and I am determined to never be the one impeding traffic.
They have the car now and we are waiting to hear what they find. I'm hoping if it has anything serious that they will replace the trans and torque converter rather than throw parts at it. I was told that the dealers don't usually rebuild the units but just replace them.
The dealer said the best they can do is a software update and then it will take a few hundred miles to relearn our driving habbits and that still may not take care of the issue. Sounds screwy to me that it shifts fine for 47,000 or rather 49,000 miles and then shifts harshly. I had a typo on the milage in my origional post. We have put about 4,000 on the car before it started having the trans issues. We will find out tomorrow if it helped.
The transmission still bangs into 2nd gear and slips even when driving very gently. They claim it's normal for it to do that.????? It didn't do it before???
They were also supposed to repair the Sirius/XM radio that keeps dropping the 50's station. They said it's not the receiver but that the 50's station always does that.
We have three other vehicles that don't have that issue with that channel, or any stations for that matter.
I think we wasted our money buying the car max extended warranty!
Sorry ur having so much trouble witht he tranny. We have the same car. Bought mine new. It is a great car, but I can understand your frustration.
The people on this forum have witnessed, experienced, or discussed just about all that has ever gone wrong witht his car. You can see from my number of ports that I am not one of them.
I would put the car in a "sink or swim" situation..
Since the dealers have checked it and it is supposed to be mechanically ok, I would reset the ECU and give it a thorough workout (SAFELY). I would turn off the traction control and manually row through the gears in the "S" mode......... drive it hard for 30-50 miles. Then I would put it in the "C" mode and drive it like grandma for 10 miles.The car makes a tremendous amount of torque. I would either break it so it could be repaired or be left thinking "Wow".
Since the techs are saying it is ok/normal, I would find another one on sale at a dealer and test drive it.......
Ihave sometimes lost a station when on the highway. I always thought it was due to a weak signal as the terrain changed (trees and hills). I have never experienced a lost around the/a city, unless the car was in the garage....
After mine was at the dealer for the timing gear repair, it started doing this. I suspected it was because they disconnected a transmission fluid cooling line, lost some fluid, and didn't re-check the level. When I took it back, they did say it was "a little" low, and did the TCU reflash. I suspect it was the fluid level correction that solved the problem and not necessarily the reflash. It had been running he same TCU code for 30K miles, so why start acting weird all of the sudden? And the only thing that changed was pulling the engine for the gear repair, which I know meant disconnecting some transmission lines. I would almost bet that yours is low on fluid, and it doesn't take much to make a difference.
Anyhow, after I did my own transmission fluid change, I can see how difficult and time consuming it is to get the level correct. First, you fill it by pumping fluid into through the drain plug. You have to pump more fluid in that needed, then warm it up to specific temperature (45C/113F). With the engine still running, you open the drain plug and let the excess stream out until it slows to a trickle. The problem is, this isn't operating temperature, but just a brief point on the way up, so you have to be quick.
