help with pict
Old Oct 9, 2012 | 10:13 AM
gonzomtl's Avatar
clk 500
help with pict
hi
whant to change my radio with a dvd unit hl-8802 gb
would it fit ...and what s this connetor that i found behind the radio
Old Oct 9, 2012 | 09:02 PM
Clkboi's Avatar
CLS550 4Matic
Kev should be able to answer this
Old Oct 9, 2012 | 10:03 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
I'm not certain, but I believe that will fit the pre-facelift (i.e. up to MY2004) CLK. That connector is part of the cell phone prewiring. Oh, and one more thing - if you have the Bose system, I don't believe any aftermarket radios will talk to it via fiber optic, which means you have run new wiring to the trunk to tap into the analog speaker wire there. Also, with Bose, most people who bypass the fiber optic amp/attenuator are very displeased with the sound of the speakers, so a full radio replacement means new wire, probably a new amp, and new speakers.
Old Oct 9, 2012 | 10:15 PM
gonzomtl's Avatar
clk 500
ok thx whas wondering with the fiber optic
if the new unit has fiber optic do you fink it will work..
Old Oct 9, 2012 | 11:16 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
As far as I know, there are not aftermarket units that will work with the fiber optic amp, but I am no expert in this - I;d check with the manufacturer. I know that the old D2B fiber was a proprietary system, but someone cracked it since Dension's IceLink would work to attach an iPod, emulating the CD changer to use the OEM radio controls. I also seem to recall an adapter that would attached to the fiber and allow you to add your own analog amp, so it seems there are some D2B devices, so maybe this head unit can handle it, but again, I am not very familiar with that unit.
Old Oct 10, 2012 | 09:08 AM
gonzomtl's Avatar
clk 500
if i look carefully it seem that the two octic cables are ...one for the phone and one for the cd
Old Oct 10, 2012 | 02:22 PM
Clkboi's Avatar
CLS550 4Matic
The (hl-8802 gb) is it this unit? Have you already ordered it?
Old Oct 10, 2012 | 02:41 PM
gonzomtl's Avatar
clk 500
nope but it s this one
Old Oct 10, 2012 | 02:42 PM
gonzomtl's Avatar
clk 500
tried today to unplug the cd ...and the sound on radio stopped playing..
Old Oct 10, 2012 | 10:03 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Yes, the fiber optic system is a "ring". if you unplug any device, you interrupt the signal in the ring and then no devices work. If you don't want the CD changer, you can buy a bypass adapter from the dealer that you plug the fiber into to complete the ring.
