Hood Vent Removal?
Old Oct 21, 2012 | 06:51 PM
CLK550 $wagger's Avatar
White CLK550
Hood Vent Removal?
Im trying to figuare out how to remove the vent on the good because I would like to paint it black but I can't for the life of me figuare it out. I did open the good and saw 2 torx screws holding it down on each end but after I removed them and tried to remove it it feel like there is more holding it down... I just can't see to find it. Can anybody help me?
Thanks!
Old Oct 21, 2012 | 08:36 PM
Zhengyucoo's Avatar
Clk350 SL550 GLA45 GLC63 Raptot
There are little things holding it along the edges inside... Gotta pry it out. There are a lot of them... If you look carefully you can see the little squares... I suggest paint it with plasti dip with out removing it.... Just tape some important parts.... Very simple
Old Oct 21, 2012 | 09:25 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Yep, after removing the screws, it's just held in place by metal clips. They can be quite stubborn, and after the plastic vent has spent a few years out in the sun, it can be quite brittle and break easily.
Old Oct 22, 2012 | 09:14 AM
White CLK550
I was actually going to be using plasti dip! Thanks for the help guys! Looks like I will be painting it while its still attached.
Old Oct 22, 2012 | 09:49 AM
Zhengyucoo's Avatar
Don't forget to cover the wind shield sprayer
Old Jul 31, 2013 | 12:47 PM
Paulers's Avatar
CLK550
Update to an old post
The little squares (part of the Plastic clips) need to be pushed gently toward the center of the vent. If you push down they will not release and will break. The clips on my 07 are plastic and will break if you force them.
Old Sep 11, 2014 | 07:35 PM
leelo1989's Avatar
2005 clk 1.8 kompressor
Did you ever paint your bonnet vent black ? Have you any pics ?
Old Jul 23, 2019 | 05:11 PM
marsello's Avatar
2007 mercedes benz clk350
I am looking for a dy video to remove vent from engine hood for a 2007 clk 350 mb convert
Old Jul 23, 2019 | 05:13 PM
clydem's Avatar
2005 320CLK Cab
Spot-on.
And underline very brittle and a PITA to put back on. Ask me how I know.
Old Jul 23, 2019 | 05:15 PM
BF_JC230's Avatar
2005 w203 C230
I’ve never seen a video and I’ve never heard of them (this old) now not breaking a few tabs.
luckily, the screws/bolts will bolt it in place.
Dealer even needs a helper or two to pry/push/unclip while performing this task.
Old Jan 16, 2021 | 04:10 AM
User 42722's Avatar
WIPE NEW will make them look new
My 03 SL500 had greyed vents. I taped off area around vent. Then I cleaned with a diluted isopropyl alcohol mix (50-50 distilled watter).
Next is the Wipe New cleaner, a saturated pad.
Finally is the Wipe New solution, again in a saturated pad.
Cleaning the holes and applying in the holes is challenging.
QTips are one way. They may be better.
Regardless, the product looks good and last for over a year or longer and it looks great.
Currently Active Users Viewing This Thread: 8 (0 members and 8 guests)
