lowering a clk500 cabriolet
Old Apr 2, 2013 | 10:41 AM
Gary C's Avatar
2004 CLK 500
Ok, I have had my car for 6 months now and it is time to customize. Nothing to radical. Going with some 18 inch wheels. I know most go to 19, but I dailey drive and think 18 is the perfect balance, of looks and driveability. I want to lower a little, for looks and a little better handling. I do not want to go full coilover route. I am going with h&r springs. They are the only ones that make specifically for the cab. 1.3 front and 1.1 rear which should just be about the perfect drop to even the front to rear gap. Now for my problem. I cannot find shocks and struts for lowering springs on a clk500 cabriolet. I could just put the springs on with the stock struts and shocks, but will need to upgrade sooner or later and do not want to be stuck with no options. I might just get new wheels and forget about lowering. Any opinions guys?
Old Apr 2, 2013 | 02:27 PM
omega48er's Avatar
2009 clk-350 (Black) AMG, 2009 clk-550 (Pewter) AMG
i believe you can go with koni yellow or bilstien hd.
Old Apr 3, 2013 | 06:14 AM
Gary C's Avatar
2004 CLK 500
As of now. There are no part numbers for koni sports or bilstein sports or hd for the convertible. If there is anybody in the aftermarket field that knows any different let me know. Also if they say for a coup, they will physically fit right? Or is the rear suspension different on the coups and verts.
Old Apr 4, 2013 | 12:47 AM
Louie D's Avatar
2015 E400 CAB, 2010 Jeep Compass, 2009 E350 Sedan
Go here http://www.koni.com/finder/ for the part# on Koni. Coupe or Cab samething.
Old Apr 4, 2013 | 08:07 PM
srmauer's Avatar
2009 CLK350 Cabriolet
Are you ready for a slightly firmer ride?
Old Jun 21, 2013 | 06:42 PM
Gary C's Avatar
2004 CLK 500
The ride is so much better than I thought. Yes a little firmer but so much better handling. Worth the trade off. And looks are subjective, but I think looks so much better.
Old Jul 6, 2013 | 09:35 PM
demidion's Avatar
2007 CLK550
Ok this sounds like a great idea... I have a 2007 CLK550 cabriolet and I went to the Koni site, I don't see a 550 listed, they list the 500 don't know if this would be the same or not. Any other lowering kits for the 550?
Thanks!
Old Apr 17, 2014 | 10:58 PM
Kevin9664's Avatar
2011 E550 Cab & 2015 ML400
I have an 06 500 coupe that was previously lowered. I might be getting an 07/08 550 convertible with stock springs. Would I be able to switch the springs on the two cars or are they different?
Old Apr 17, 2014 | 11:02 PM
pskdude's Avatar
2004 CLK500 - W209 - Cabrio
hello
Did you ever find out if Bilstein makes the part for the clk500. I also want to lower my Cabrio on the H&R springs but not sure on shocks
