Headlamp Range Adjust too low
Today, however, I got a situation where both beams were pointing low and stayed there. Not entirely on the bottom though (they would come up just a touch from the lowest position) but still way too low to be driveable at night.
I used to think it was a motor issue, but now more inclined to think its a control issue. Otherwise no reason for both motors to move in an identical manner.
The front axle sensor. I can't see anything wrong with it but I am not an expert.
No idea where the rear axle sensor is.
If this does not work you could have a faulty sensor & need to do a setup with Sar & lightbox after replacement of the faulty sensor.
Both lamps are messed up now. The left one is low and the right one is even lower (so a sort of combination of the two problems).
Probably going to sell it.
They had loosened the adjuster clamp on the front sway bar & not re-tightened it. That's when I took the trouble to find out how the whole system operated & how to set it up.
Anyways, took it to the dealer and they fixed it. No charge. Turns out it was the sensor arm position which was flexed the wrong way.
They also performed a recall for a wiring harness on the camshaft position sensor.
And on the way home had a really bizzare thing come up...almost like Toyota S U A.
