CLK500 on dyno, some pre-run problems.
I want to run my CLK500 on the dyno just for fun, but i have some problems before i can do the actual run.
1. How to disable kickdown? The dealership checked my car and my car doesnt have a kickdown switch. The kickdown function is activated through some potensiometers in the accelerator pedal. So, for the car to not change down when i floor it, what to do?
2. I have an early 2003 clk. This car doesnt have the secret menu with dyno mode in the instrument cluster.. How do i deactivate ESP/ABS and all that stuff?
That said, I would suggest that you let someone with experience work the controls a couple times before you try it yourself. You need to also make sure someone who knows what they are doing, secures the car. You don't want to be on youtube going 0-80 in 30feet into a wall......
Your wheel speed may get as high as 140-150 mph (if you can turn off enough controls).
unplugged the switch and went for a test dirve... and, no kickdown.
So.. that solved one problem..
I was thinking to remove fuse number 56-59-60 from the engine fuse box.. Those three fuses are the ones for ESP.. will that work?
Looking forward to seeing your results and most importantly, have fun doing it
The numbers:
275bhp (5300rpm)
408Nm (4300rpm)
About 20% power loss in drivetrain, so corrigated numbers are:
330hp
489Nm
2 gear
16 degree C ambient air temp
995mBar ambient air pressure
90% air humidity
Edit: forgot to add that a/f ratio was a bit lean on rpms over 4500. So a mapping specialist is gonna take a look at the car to give it a custom map that will run on E85 and also fixing the lean issue over 4500rpms..
The numbers:
275bhp (5300rpm)
408Nm (4300rpm)
330hp
489Nm
2 gear
90% air humidity
Engine and trans oil are new.. Airfilter is stock.. Im gussing it has never been changed. I just cleaned the filter with some compressed air a few weeks ago. Sparkplugs is also never changed. the car has done 80.000km now.
I bought the car used, so maybe the guy that had the car before me did something i dont know about? It was an old lawyer from germany, so i dont think it has done something to the engine..
Picture of the car doing the run.. A bit messy in the garage, but the guys working there are racing to build 2 cars for this weekends car meeting and racing.. they are building 2 audi RS4 full track spec..
My 08 550 (382 bhp) with kleeman headers and ECU tune (~430 bhp) read 303.6rwhp. Although I think it may be as high 320.
275/302 = .91 or a loss of 9% instead of the norm of 19% to 30% (depending on the engine variant and tuning).
I'm guessing at the meaning of the replies, but I like learning....
Biggest thing is to have fun with the car, the 209 is a great platform & I've had a bast doing a few things to mine? Again, dont take of fence to my remark, none was intended, it was me realizing why the number was so high.
See you around, great group of guys here to help you out along your modding way.
