New guy...04 CLK 320....Fuse chart..a lil help
Old Jun 16, 2013 | 01:25 AM
Djoker04's Avatar
O4 CLK 320
Hey guys, 1st time benz owner and have been putting this baby back to it's glory that it should be...(I'll give a bio later)....right now I have 3 malfunctions that are showing...SRS, Coolant and Washer Fluid level's........I just replaced the washer bump and sensor...it went away but then it came back on.....so tha's problem number one...
Issue 2: I found both Fuse boxes but as i've learned from here...no chart or locations on the covers...Looking for the fuse for the Antennae AMP and left Drivers side Parking light....Bulb is ok so it has to be a fuse.....
any help would be appreciated..
KF
Old Jun 16, 2013 | 01:52 AM
Louie D's Avatar
2015 E400 CAB, 2010 Jeep Compass, 2009 E350 Sedan
I believe there is a diagram in the fuse box by the drivers side door.
Old Jun 16, 2013 | 02:57 AM
Glyn M Ruck's Avatar
Super Moderator
This is in the W209 Wiki here:
https://mbworld.org/wiki/index.php/F...se_diagram.pdf
Old Jun 16, 2013 | 11:52 AM
Louie D's Avatar
Good one Glyn that's the one I posted that awhile ago. Glad to see it came to some use.
Old Jun 16, 2013 | 06:02 PM
Djoker04's Avatar
O4 CLK 320
Thanks for the link.....it did help out......by finding all fuses for the key in tact, but I'm still having intermittent Useage is there a simple program mode i can do......
and I have no idea what fuse is for the parking light......can't figure out why it went out in the 1st place......only thing I did in that area was assemble the washer reservoir......
Also any idea on the SRS? How is that reset or fixed? I'll look that up now....
Thanks guys for the assist...
Old Jun 16, 2013 | 08:43 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
SRS errors, even after repairing the fault, can only be reset with proper equipment like SDS (Star Diagnosis). There may also be some aftermarket system (like Carsoft) that will do it, but inexpensive, generic OBDII scanner will not reset SRS error.s
Old Jun 16, 2013 | 11:36 PM
Djoker04's Avatar
O4 CLK 320
Cool thanks.......
Old Jun 17, 2013 | 03:54 AM
Super Moderator
The lights are all electronically controlled by the SAMS. If it is not a bad connection or blown lamp ask them to check the light while the car is connected to STAR.
Old Jun 17, 2013 | 06:24 AM
Djoker04's Avatar
O4 CLK 320
Guess I need to find someplace that has that system.......
Old Sep 19, 2016 | 10:52 PM
Inno68's Avatar
Mercedes Benz CLK500
Hope this helps me out , I have a 2003 Clk 500 , The vehicle never came with a fuse chart .
Just installed a new AC Compressor , even after charging with freon , The Clutch doesnt seem to come on , I suspect a fuse now after checking everything wlse .
Thanks for Posting the Chart
Inno
Old Sep 20, 2016 | 08:13 AM
insame1's Avatar
2006 E55, 2012 GLK350 & 1992 190e sportline
Inno
did you diy this?
Old Sep 20, 2016 | 09:21 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
FYI, the AC compressor uses and internal swash plate so you can see the clutch engage. You probably need to scan codes from the ACC to see what's going on - low pressure, etc. You'll need SDS or another tool that reads beyond ECU codes.
