URGENT: Aftermarket Nav Install Question
Problem 1: no sound- they are talking about doing an amp bypass on the factory amp. I'm guessing this is not necessary.
Problem 2: manual shut off- the Jensen aftermarket unit doesn't turn off with the car, it has to be manually shut off, and screen still stays illuminated.
I drive a 2005 CLK320 coupe with the Harmon kardon system
Need to get them an answer ASAP before they charge me additional labor.
As for problem 2, they probably used a generic wiring kit for the install. Most cars have w wire for constant 12v and a wire for switched 12v. MBZ doesn't have this. The radio wiring harness only has constant 12v, then it uses signalling over the CAN bus to turn the radio on and off with the ignition. When installing an aftermarket system, you need to tap into the cigarette lighter to get switched 12v. This is also a good place to tap into the illumination circuit (another function that is CAN bus controlled).
My advice is to find another installer as these guys don't seem to know what they are doing. Also, all of this information has been posted on the forum many times, plus there is a forum dedicated just to audio systems. I'd suggest reading up on all of this so when you do talk yo the installer, you will be informed and not left to their mercy.
I'm going to relay that information to them when I go and attempt to get all my installation fee back. They ended up giving up and putting my factory system back in, unfortunately it was a little late to have them salvage the project. And they still are trying to charge me $100 labor, of course.
I'll read up and try to see if another place in town could possibly do it. When I brought in my car, they seemed as if they were confident they could handle it, promised me it back by end of day so I definitely didn't question them enough.
Of course, I can wait until I am back in LA and get it done at Sonic or somewhere else. I am in my hometown aka hicktown northern canada and they have never seen a benz before it seems. For problem 1, they wanted to just power all my speakers from the head unit, just basically removing the function of my amp completely. At least that is how they explained it when I picked up my vehicle. Really, they have no clue what they are doing.
This info helps, thanks again
the process is quite straight forward if you can do it yourself and use pics from this forum as examples. also, this being a benz,most shops want to charge higher. so, if you can do the installation yourself, do it and haven a shop tune it for you. oh, check out the DIYMA forums for shops in your area.
1) you can not use stock amps and speakers with an aftermarket unit due to the fiber optics
2) please, please do not use crap brands like jensen. if you are on a budget get an older version of kenwood or Alpine.
3) if you need help picking equipment let me know, we can look at some options (used and new)
4) get a 5ch amp or if you want get loud, we can look at 2 separate amps.
Speakers still have a voice coil. Therefore they need an analog signal to be driven which means wires. Ergo, OEM speakers can be reused. One just has to route wires to them or splice into existing wires.
Plus it woildnt be worth keeoing stockies if you are switxhing everything to aftermarket. A pair of decent components will run under 200 on budget.
