Removing the CD Changer from the glovebox
Old Jul 30, 2013 | 09:07 AM
Frank Rizzo's Avatar
2024 GLE63s
Well, the CDC crapped out. I had not used it in a long time and when I did, the display just says "error".
It occurs me that I could use the space for a Glock, so I want to take it out. I cant figure it out, all the fasteners are hidden.
Rud, do we have any service bulletins or pics??
thanks
Old Jul 30, 2013 | 01:30 PM
ambit's Avatar
09 CLK550
My 2005 coupe has single black screw at the right-hand side of the changer going up into the top of the glovebox. I had to crawl upside down in the passenger side footwell to see it.
Once that was out the whole unit + metal shell slid to the right to pop out the only other tab holding it in.
A 3 wire connector and a orange fiber cable clipped in the back.
Old Jul 30, 2013 | 03:55 PM
Djoker04's Avatar
O4 CLK 320
thanks
My $.02 but the glove box to me is to far away to get to your gun. Unless it's to lock it in, which I would use the center arm rest....as for when driving (IN TEXAS) I put mine between the seat and the arm rest in it's holster. Don't have my carry permit but we can carry it concealed in our cars. LEO's approach from the passenger side and as a courtousey I inform them if needed to. Just my opinion.
Old Jul 30, 2013 | 10:25 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
FYI, you'll need a fiber optic coupler to connect in place of the CDC to complete the ring. The dealer sells them, I think about $10.
Old Jul 31, 2013 | 12:30 AM
2024 GLE63s
Any help with a part number and screw location buddy ??
Old Jul 31, 2013 | 10:57 AM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
The screw is on the top right side of the changer. There is a small metal bracket that protrudes from that corner of the changer and the screw goes through it and into the "roof" of the glove compartment.
Here's a thread that discussed the coupler:
http://www.benzworld.org/forums/w220...ml#post4659371
Note that the post relates to an S-Class and was solving a different problem, but it has the part number and explains how to remove the existing connector and install the coupler.
Old Aug 1, 2013 | 09:13 AM
2024 GLE63s
Once again, you are the man of massive help.
Old Aug 2, 2013 | 08:45 PM
chokah22's Avatar
2005 C230
Unhappy
ok, I'm new to this forum. Please excuse me if I'm posting in the wrong room or what not, but sounds like you guys might be able to help me
I have a 2005 C230 sedan. I was listening to a CD (CD 2 I believe) in the CD changer (CDC) it was done playing and was moving on to the next CD (CD 3). I wanted to listen to a song on CD2 so I hit the number 2 on the keypad on the front console. The CDC is in the glove compartment. The front console displayed "CDC Error" :-/ I opened the glove compartment and slid the CDC's cover opened and tried hitting the eject button, the light on the eject button blinked but "CDC Error" displayed again on the front console. I tried switching to radio, worked fine. I hit CD and it played CD0 (the one in the front console) fine. So I then hit CDC button.."CDC Error" still :-/
I really hope I don't have to replace the whole CDC changer. Any way to get the CDC magazine out? I tried pushing it, moving it a bit, and keep trying the eject button but no luck..
Old Aug 2, 2013 | 09:59 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Normally I'd suggest you head over the the W203 forum, but in the case, there's no difference (the W209 and W203 share the same chassis and many parts) and it's pretty much related to the topic at hand. What I would do is try a "reboot" of the CDD - pull fuse #24 (on the cabin fuse panel).
Old Aug 4, 2013 | 10:17 PM
2024 GLE63s
OK....maybe i'll try this before yanking the CDC ^^^.
Still....if I pull the changer....I could put my weed er .. I mean Glock.... in the space.
Old Aug 5, 2013 | 01:12 AM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
...or owner's manual, or iPod or parking tickets...
Old Aug 5, 2013 | 04:06 AM
bheng's Avatar
2003 CLK 320
once the CD changer is removed.... there is a lot of space...
when I removed mine, i sat there wondering if I could fit a slim gaming system in there lol
